While digging around on geizhals.de for a potential "less than 120 mm radiator" solution, I stumbled upon the Raijintek Forkis DCC Ultra, a low-profile CPU block with integrated pump. It's been listed since begin of September 2023, but apparently was announced in February this year, to be "quickly released". Well, better late than never
Copy + Paste from the spec sheet:
Pump:
Sockets:
Link to the product page: https://www.raijintek.com/en/products_detail.php?ProductID=187
cu, w0lf.
Dimension [W×D×H] | 80×84×45 mm |
Material | Aluminum + POM + nickel-plated |
Weight | 680 g [w/o clip] |
Screw Threads | G 1/4" |
Pump:
Bearing type | Ceramic Bearing |
Maximum Head | 3.8 meter [Max.] |
Maximum Discharge | 750 L/H |
Maximum Pressure | 21.7 PSI |
Life Expectance | 50,000 hrs |
Noise Level | 45 dBA [Max.] |
Speed | 1800~4,800 RPM |
Voltage Rating | DC12V |
Input Current | 1.5A ±10% |
Connector | PWM 4-PIN header /SATA header |
Sockets:
Intel® | All Socket LGA 17xx / 115x / 1200 / 1366 / 201x / 2066 CPU (Core™ i3 / i5 / i7 / i9 CPU) |
AMD® | All AM5/AM4/AM3+/AM3 CPU |
cu, w0lf.
