My online shop is getting absolutely hammered with traffic ? . At this rate it is going to be sold out within a few days (to a week). @SFF community : go get one before it's sold out, and thanks again for the support. Demand is absolutely overwhelming.
At least it’s launching before Ali or the other ‘tubers get reviews out.
I still remember this websites performance issues when it was linked on a T1 info vid. Better make sure the shop is ready....
For res i chose this this. The reservoir will be secured behind the radiator. The radiator will be installed behind the body on a special frame. I am still waiting to receive all the parts of my future build. In the meantime, I only have this. In the last photo the rad frame is waiting for painting.
Well deserved! I'm glad I got my order in early.My online shop is getting absolutely hammered with traffic ? . At this rate it is going to be sold out within a few days (to a week). @SFF community : go get one before it's sold out, and thanks again for the support. Demand is absolutely overwhelming.
I think that the mounting kits should be improved. When I using the original mounting kits, it's hard to lock those screws and a bit uneven. So the temperature performance was not good as I thought. After changing to EK's mounting kits (from supremacy EVO), than it performed much better.
| CPU | R5-2400G 3950 mhz @ 1.425V |
| Pump | DDC310 |
| Rad | Alphacool st30 V2 |
| Fan | TL-C12 @ 1000 rpm |
| MB | MSI B350I |
| Room temp | 24 C |
| Taobao customized | Aq | Aq+ek mount | EK classic AMD | |
| CPU idle | 29 | 30 | 29 | 28.5 |
| water idle | 27 | 27 | 27 | 27 |
| flow | 125 | 130 | 130 | 176 |
| CPU burn | 73 | 77 | 74 | 71 |
| water burn | 30 | 30 | 30 | 30 |
I thought that maybe my AM4 back plate quality was not good, so the original mounting kits didn't work well. It's a bit uneven.
The mounting kits from EK would make sure that it mounted more flatten.
Since the intel system has its own back plate, maybe this would not happen to it.
I've now seen a couple of reports about the AM4 mounting kit. I just ordered one of these, do you guys think it's worth canceling the order? I don't want to pay $25 in shipping fees just to have to return a product if it isn't performing adequately.
@Nouvolo - Would it be possible for me to have my order delayed (without a refund)? I am switching from Intel to AMD in November and won't need this right away, so if there is a concern for QC, I would want to know if this could be a possible option rather than refunding the order or (even worse) having to return it.
yeah same, I also just ordered today.
Had to pay 29$ shipping, what is pretty steep if it doesn't perform well...
that one is not DDC, most probably will not fit.Is this compatible with pumps like this low profile DDC clone?
that can bring the total size down to 39mm
To clarify about backplate (the part installed underneath the motherboard), so that we are all on the same page:
Aquanaut Intel 115X - motherboard backplate included
Aquanaut AMD AM4 - motherboard backplate NOT included
This is standard arrangement for most water cooling blocks products. All AMD AM4 motherboards include their own backplates. Intel 115X compatible backplates are all similar. You do not have to use the Aq Intel backplate if you have another one you are more comfortable with.
I am using the original AMD backplate.
Maybe the quality of backplate was not good, so it cause the issue.
Maybe add some washer like ek Classic amd does would help solve the problem.
I’ll do more test for it.
