I'm loving this thread even though the recent discussion is a bit beyond me
very interesting to read
Suppose the development of new direct plug units wasn't blocked, is this something that could be resolved if a new PDCB was designed with meanwell ps_on/5VSB in mind? Even if it added 2 more wires for that functionality it seems like that would be optimal for simplicity.
I'm looking forward to what aquelito can share with us
I have recently found out that I can continue with the development of a Plugin unit.
I can certainly add request the +5VSB and PS_on for a meanwell, but that means it's a circuitry to support a single type of PSU. It presents the following issues:
1. Additional cost and complexity to the board.
2. Requires additional wiring. It is not just two more wires, it requires a different set of connectors as well.
3. It only really cover Meanwell PSU. Even though they are the most preferred 12V PSU, they are still very very niche.
So those issues will prevent me from wanting to invest in it. A new PDCB is not out of the question, something that is much more commonly available than G-Unique but it does present a few issues that I have not though of a solution for yet.
1. G-Unique uses soldered pads instead of connectors. This means all of his stuff is built to order. If I use connectors, it greatly increases the amount of board space for it. If I use solder pads, or soldered wiring, it means that all off the cables are permanent, a solution I'm not found of.
2. Support the PDCB with high power AC-DC units. I will not be modding any devices, but getting power to the PDCB is a bit of a challenge. So far I'm integrate Meanwell units, but it's hard to keep compatibility across the board. It likely means I'll have to stock Meanwell AC-DC units and provide them as a full kit.
At the end of the day, I'm just a hobbyist, not a full fledged business owner so my time is limited and I'm only scaling up what I can do.
