I have a contact who uses the same model of DDR5 SO-DIMM RAM kit as yours and who advised me these settings for 8000MHz CL38 (yes! yes!
) where he holds more than 2 hours of Y-Cruncher (preset VT3) and more than 50 complete cycles of TestMem5 (preset 1usmus) stable, these are his everyday usage settings on his DeskMini X600 (bios "4.03.MEM01") and APU Ryzen 5 8500G, I have not yet had time to test them but if you want to try, you will gain 30~40% additional performance on your iGPU due to the significant increase in RAM/VRAM bandwidth, however you must remember to set your UCLK ratio to "UCLK=MCLK/2" (and not "UCLK=MCLK") to be able support such a high frequency, here is the ZenTimings screenshot he provided me which contains all the details of his voltage, timing and internal RAM resistance settings, to get 8000MHz CL38 @1.40v stable:
Correction: this is a Kingston FURY Impact SO-DIMM 5600MHz CL40 kit but in 2x16GB or 32GB (and not 2x32GB or 64GB like you) but there is a way with a few adjustments that it will still work for you.
