Log BAOCASE Mini | 2.77L 7800X3D & 4060Ti & internal PSU(with X600-STX 12v input MOD)
sandyware
34
58
Wow!
Stupid question: I care barely cool a Ryzen 7700 non-X (65W TDP) with the same cooler, but you use a 7800x3d (120W TDP). Makes me wonder if there's something fundamental in setting up things that I'm missing or doing wrong.
In the recent build, I tested the temperature of 7700 using the AXP90-X36 cooler. With the power limit unlocked, running the AIDA64 FPU test is 90 degrees at 110W power, with a frequency of 4.7GHz and a room temperature of 25 degrees. Cinebench R23 10min test got 18600 pts. I think it's very sufficient for non extreme loads.
Reactions: bn-l and itchybun
nightshift
289
188
I have a question - maybe it was explained and I just blinded it, but how do you connect that riser to the x600 mobo?
BaK
982
965
@sandyware is the GPU only getting power from the riser?
I think you must be referring to that picture:
Since the M.2 slot can only provide around 7W, the yellow and black wires we see above are certainly helping in raising the power to match the 75W of a regular PCIe slot.
But 75W is not is not enough for an RTX 4060Ti.
The latter is then also getting power from the MeanWell PSU directly, that should be the black wires we see on the bottom right of the picture.
Connecting the PSU to the GPU could lead to the 'always on' problem, but this is not the case with this specific hardware as mentioned earlier in this thread.
Reactions: Curiosity and bn-l
BaK
982
965
The riser is actually an ADT R43UF 4.0 M.2 to PCIe adapter, attached to the M.2 port on the back of the X600 board.
Reactions: bn-l
nightshift
289
188
Thanks. Didn't know these have an M.2 slot in the back as well. To be honest, there's a 4060 from Manli, that's little less than 150mm in length, so it can fit behind these small mobos with ease and could make something like a Velka 2. It would leave more space for the psu.
sandyware
34
58
Perfectly right.
Reactions: BaK
bn-l
I love what you've done here.
Do you think there's any chance the 7950x could work (with power tweaking) with a bigger cooler (axp-100cu with a 25mm fan) in a custom case?
hrh_ginsterbusch
971
394
wp-devil.com
With a 25 mm fan you could just skip out the axp-100 and use an axp120-x67 instead. Much more headroom (because bigger heatsink), and combined with an Air Slimmer 120, this thing rocks!
cu, w0lf.
bn-l
cu, w0lf.
*I meant a 15 mm fan. Or maybe my is-60 v2 with its noctua 15 mm fan (which is hugely overpowered for my current 65w cpu)
hrh_ginsterbusch
971
394
wp-devil.com
IF you use a 7950X, IT IS NOT.
You may read up how well the 7950X performs with the AXP120-X67 + Air Slimmer 120 soon, over at my build thread. Probably this week.
Until then, DalrayMyo has done some interesting tests with various overpowered CPUs (7950X, 14700k) and tiny heatsinks:
66 mm LP CPU cooler + i7-14700k:
100 mm LP CPU cooler + Ryzen 9 7950X:
53 mm LP CPU Cooloer + 7950X:
Deep-dive into various fan sizes + 53 mm LP CPU Cooler + 7950X:
cu, w0lf.
msystems
810
1,416
Incredible build. Can you explain in a little more detail how placing the resistor there allows you to use 12v input?
Reactions: protocolsix
sandyware
34
58
Of course, the motherboard VRM can provide approximately 120W CPU power, and the 7950X does not need to replace the cooler at this power consumption. All core performance can be retained by 85%.
squirrel_slayer
@sandyware Are you aware of any spots on the motherboard one could pillage 12v power from? I'll likely end up going the same PSU route you took, but it would be nice to be able to power this Tesla P4 I have in mine internally of the board.
mcmaxmcmc
12V Input Hardware MOD for X600:
Someone may be curious about how I did it.There are two methods:
1.Direct Plug Components: Connect to any of the solder pads in the red frame, passing a 100K resistor to ground.
2.SMD Components: Choose a 100K resistor in 0402 size and solder it on top of the resistor shown in the picture. Don't remove any components.
Hello, I've recently received the sister motherboard to this board, the X600TM-ITX. I'd like to do the 12V mod as well, but there is no tutorial for that anywhere. With some light inspection, it seems my motherboard uses the same power circuit as this, the STX. However, the position of the components on the TM-ITX are a little different:
I have a multimeter but no schematic. Can you tell me what the new 100K Ohm resisters are connecting to in relation to the PU23 chip? I can then trace out the connections and make the proper mod on my end.
Reactions: SFFMunkee
