Production ONE2 DISTRO 400 - A 12V Power distribution board
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
Concept thread of discussion of a 12V solution.
Idea: a board that can take 12V input, provide 24 ATX output, PCIE output, and with ripple suppression. Allows you to use a variety of 12V psu.
Input:
2x 4 Pin CPU EPS
4x m4 Screw Terminals​
Output:
2x 6pin PCIe - connected to load switch
1x 4pin CPU - connected to load switch
1x 4 pin CPU - ready load
Board size:
50mm x [tbd] x ~20mm.
Block diagram
Pictures first:
Pretty cute right? :D
What is it?
ONE2 DISTRO 400 is a versatile power distribution board with ripple suppression. It is designed to work with picoPSU, aka Plug In DC Board. It is compatible with any 12V power supply with a ripple of 240mV or lower.
It features, a first in the SFF scene, WAGO terminal connectors. These allow you to use any wire 18-12AWG, without any terminals, so you can get that perfect exact length. No tools required to use these terminals.
It is also compatible with any external 12V AC-DC Adapter, provided you supply the correct wiring.
Here is the wiring diagram.
SPECS:
Max Board Power: 400W
Board power using 8 pin connector: 300W (for safety reasons)
Board power using 4 wire WAGO terminals: 180W with 18 AWG, 300W with 16 AWG, 400W with 14 AWG​
FULL KIT:
2X 6 pin to 6+2 Pin PCIE (length TBD)
1X 4pin CPU (length TBD)
Includes Plug In DC Board with 4pin Mini-Fit connector
Includes 2x SATA
Includes SYNC line
Ripple suppression: max 120mV Pk-Pk on output rails
Available as BOARD ONLY for modders.
Board will be black, with white silkscreen.
Cable kit will be black with sleeving (still working out details with vendor)
1 Year Warranty, Shipped from USA. Sold exclusively at shop.j-hackcompany.com (https://j-hack-shop.myshopify.com).
Retail price TBD. Expected release date: NOV 2018.
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
Go forward with this, there is two main shoot offs we can go.
1. Compatibility with pico psu. The distribution board will use a load sensing circuit to turn on a load switch (or relay) to distribute 12V power to PCIE outs. However 12V rail will still be on on the input side. Positive is less wires.
2. Full 24 ATX out. The board has additional standby circuit that can put the PSU into standby mode, completely disabling the 12V rail. You end up with more wires, which I hate.
3. Create both board designs, with one for smaller builds using the load sense circuit. The other one for bigger builds.
Paging @Link1712 to explain his project.
Reactions: Link1712
Link1712
Hi there!
So here is the PSU that was custom made by pico box for our case.
This thing can handle 600W of combined power, which is split into 300W for the PCIE lane alone and another 300W for ATX 24 Pin, EPS and SATA. For both Power Rails you'll need a 300W External power brick.
This is what the psu looks like.
and here the Power brick
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
Hi there!
Very nice. What was the reason you went with a 24V design? Your board ended up very large.
Also I haven't seen pico box very active. Are you in good communication with them?
RoLexus
140
65
byanh.com
I'm going to design that, even haven't much time and take some time to search.
My idea is a long direct plug board with 500W, 12V input, with remote power switch and noise filter.
Link1712
So the input is 19V. It assures maximum efficiency so the psu could almost be cooled completely passive. Almost i say, because there is a little bit of airflow through the case recommended, although passive cooling hase been tested successfully.
The reason why we went with this solution is due to our case design. I'd wish to speak openly here, but our patent is still in the registration and i can't post any details about it before that happened.
Link1712
Ah what i forgot. Yes i am communicating with them actively. They will reply to me within maybe 12h usually.
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
That's fine. I do know that you can find 250W 12V psu available. You can save a lot more space by making it a 12V design. I hope your project goes well but the community can give a lot if you're willing to divulge us.
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
Thats good. Do you think they can do a custom board as the thread stated? Where are you based?
Very good. Do interest us. I would say it'd be difficult to get wide acceptance because of minibox patent. I started noticing fewer pico psu in the market. Seems that they're aggressive with their patent now.
Link1712
I can surely make something up with them. But it depends on the specs.
RoLexus
140
65
byanh.com
For 12V if the input is filtered out side the board, board size is not too big, enough for almost mobo,
I found a cheap tiny 12V 600W PSU with less than 10mV Vp-p, I will order and install in my new EATX case to test next month.
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
Have also thought about a server psu? Miners use hp common slot psu with a breakout board. While not more power dense than an SF600, it's form factor is pretty slim.
Link1712
These are usually super loud tho. The 40mm fan ramps up to earstriking rpm and even by swapping those, they will be super noisy.
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
Yes, but that's because they're dealing with high outputs. If you derate and use a quieter Noctua fan, you can still achieve the same output with reasonable noise.
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
I'm wondering if @Zackmd1 would be interested in this.
We do need to determine one hard path of design. I'm thinking to support a 100W cpu and 150W gpu. If others are interested please chime in.
Reactions: Zackmd1
Thehack
Creator
Mar 6, 2016
2,811
3,669
J-hackcompany.com
As I already wrote to you in PM, I would be interested in a dual PCIe solution, supporting at least 400W.
The transistor used on my load switch and riser is a BTS555 rated for 165A : shouldn't be an issue !
https://www.infineon.com/dgdl/Infin...N.pdf?fileId=5546d4625a888733015aa3f57e5e103e
I'm thinking of finalizing the specs to:
2x8 pin out, and 1x 4 pin out. Support for 400W max output. Most of the cost is in the board and design fees.
Opinion on 90 degree angle (sideways i/o like on GPUs) or vertical in/outs (like for CPU)?
