News ZOTAC GeForce GTX 1080 Ti Mini
VegetableStu
1,949
2,619
Love the result:
3lfk1ng
919
1,718
Santa Barbara
www.reihengaming.com
Reactions: WillBlackstone
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
LOSIAS
Jul 19, 2015
818
1,359
LTT Presents: CRAMMING A 36 CORE INTEL CPU INTO EVERYTHING WE CAN GET OUT HANDS ON...AGAIN!!!!
QuantumBraced
507
358
I'm thinking of an SFF case designed around this card. I'm thinking of a back-to-back design with dimensions ~ 265x180x105. On one side you will have a Mini ITX board + enough space to install a Flex ATX PSU intaking from the bottom or the HDPlex 400W. On the other side you will have room for a dual-slot card of 260mm or less -- the Zotac 1080 Ti Mini or 1080 Mini will fit. And you'll have room for a 42mm CPU heatsink, so you can install a Noctua L9i or if you're feeling crazy and want to go X(2)99, the Dynatron T318/R15 + 120x15mm fan. Overall volume ~ 5L. Super tight. Not great for dust, noise, or temps. But Linus can build a 24-core system with a 1080 Ti in 5L :D
Reactions: Boil
Boil
1,263
1,100
Grand Junction, CO, USA
You gotta work that internal power brick in there, and HDPlex does not offer any AC-DC units over 300w...
Full load (synthetics) would (theoretically) be over 500w (7820X / 1080Ti Mini / three NVMe M.2 SSDs / 64GB RAM / asst. fans)...
At this point, choice is SFX PSU or an AC-DC assembly (two HDPlex 300w AC-DC units, one KMPKT Dynamo & one KMPKT Mini Dynamo)...?
QuantumBraced
507
358
If you need over 330W then you go Flex ATX. It's like an A4-SFX but with a Flex ATX PSU, so it's even hotter and noisier if you can imagine that :D I'm betting before the end of the year someone releases a proper 400W power brick though.
But I do love the idea of a case that supports dual DC-DC where 90% of users would be okay with 300W, but for those who want to go crazy, you can mount a second one, uncover a second C14 power outlet hole that was hidden under a plate, and plug in a second power cord for the dual power brick dream :D
No, at that point you would have SFX, but I just love the idea of dual power supply in some tiny case haha.
In seriousness, if we do get a 400W brick, I do think a sub-5L case can be designed around the Zotac 1080 Ti Mini with an external brick.
Boil
1,263
1,100
There is going to be that extra space on the mobo side due to the deeper chassis needed for the longer than ITX GPU, I say an internal AC-DC brick that does 400w coupled with a G-Unique Pico-style unit would be best...?
But such a chassis would covers the smallest & most powerful Nvidia GPU available for SFF builds...
We are going to have to wait & see what Vega brings & then design around that as well...!!!
4,796
It should be more like 450-500W at stock clocks with that kind of setup.
QuantumBraced
507
358
I have a ton of respect for him, but I just can't take a risk with a modded brick regardless of his stellar reputation. I would only buy from a respected company that manufactures according to all laws and regulations.
I think what I was describing earlier was basically a slightly wider S4 Mini in a back-to-back mini tower config rather than side-by-side. I wish a highly space-efficient case existed for the Zotac 1080 and 1080 Ti Mini. It seems like the choices we have are either full-length or ITX card support. Which makes sense as designing a case around one brand's arbitrary PCB length seems silly, but I think it's fair to say a 1080 Ti is not going to get any shorter than this, so I think it makes more sense now.
Reactions: Boil and Kmpkt
