My Work in Progress 55mm H* PIO/ITX STL (* plus top and bottom sheet metal of 1.5mm-2.0mm). It is designed to be used with M3 round standoffs with 5mm OD; brass heat inserts may possibly work. The depth of my board is 190mm, so the sides are 195mm. The front is not final, I will need to make another piece to the front panel to get the Appx 245mm final width. The cutouts are designed to accept some 2mm expanded metal mesh panels epoxied in. The GPU side will be fully vented.
Build log: https://smallformfactor.net/forum/threads/tight_corners-3d-printable-b610i-pio-and-gpu.19307/
Here are some pics of the 65mm high test print. This is an H610i-PIO board from JinWei (TaoBao) and the 4060 Low Profile.
www.thingiverse.com
Thingi verse thing 6447759
![www.thingiverse.com](/forum/proxy.php?image=https%3A%2F%2Fcdn.thingiverse.com%2Fassets%2Fe0%2F96%2F26%2F07%2Fdb%2Ffeatured_preview_3a0d596d-c7e2-4513-92ca-3fbaae03fb5a.png&hash=f1c6824b0f9c746d40b49a1323a66c13&return_error=1)
ITX Case H610i-PIO and 4060 by milesvw
This is a WIP case with 55mm height (and an old attempt at 65mm height). It is the side panels and part of the front panel. Either using brass heat set inserts or 55mm M3 round standoffs with a 5mm OD.The Front Panel_E is to fix a bit of a clash with my CPU Cooler, we'll see how it works. I...
![www.thingiverse.com](/forum/proxy.php?image=https%3A%2F%2Fcdn.thingiverse.com%2Fsite%2Fimg%2Ffavicons%2Ffavicon-192x192.png&hash=a53850f3d24911cdd0f702a57d311b2f&return_error=1)
