Yeah. Just keep in mind the above image is from v10 (the Beta units). With the updates to the central spine, that yellow area now has a beam running through the middle of it, with holes for cable management.
A Pump / Res System with some way to bridge that gap (like having a res above (any shape), and a short tube to connect to a pump below) would be a good approach to handling the central spine, or just having a thinner tube res, or just having a pump that's fed properly from the top.
Also, I was looking at other pump options, and the Koolance 420 caught my eye for Winter One -- At a little less flow rate than a D5 pump (3GPM on the K420 vs 4GPM from a D5), but a
lot more pressure (5.75mH2O on the K420 vs 3.5mH2O on the D5). It's smaller but *much* better for restrictive loops, compared to the D5. It's also much smaller than a D5, and easier to incorporate into a build at 48 x 48 x 69mm. Not sure about the noise profile, so I'll look for some more reviews. Figured I'd bring it up, since the pump choice discussion is taking place right now.
Also, expect a Kickstarter Update with Airflow / Thermals / Noise this Sunday, since the perf panels were not available in the Beta. I've posted a few teasers, but I wanted to make an official update around it. And if I've got time later tonight, I'll go into a bit more detail on the watercooling stuff that was requested.
