Ventilation looks pretty awful (and if you're using ULP parts to compensate you may as well shrink further and use the case walls for passive cooling) but with feet placed on the 'side' to allow the cables to exit directly down, this could be a really nice design piece sitting on a desk.Also, can't really resist posting this:
The world's most literal "cube case". It's literally a 270mm cube.
I'm both fascinated and terrified in a way I can't explain.
Yeah I did a sketchup design that was extremely similar to this case but with 120mm fans and 3.5 drive mounting points on the backside (figured having 4x 2.5 would be better than 2!)
I am not sure if this is an improvement over their Metal Solid case, which is a very similar design but with 2x 80mm thin fans at the top and a 1U power supply at the front. I would have preferred they just updated that case with 92mm fans on the top and bottom.
I think if I build another workstation i'll be going with this:
https://item.taobao.com/item.htm?sp...YfzJIQ&id=544643552283&ns=1&abbucket=9#detail
BTW I'm 99% sure it's not a real jonsbo case.
I imagine the Raijintek Metis has the same GPU heating problems.
You need to select a colour before you can add it to the basket.Hi Guys, I'm trying to order the ZS-A4 case using an agent but there is no buy option.
Is there anyone that can translate what this mean? I know the next batch is expected to ship @ 10/22. Do they have a minimum amount of orders before they ship? Thanks in advance. https://world.taobao.com/item/54525...59.6.6FOF0.545250722227&scm=1007.12679.206343
I love this case. If only it took a full atx and had from for a 240mm rad on bottom and front and i would be all over it. love this design thoughOne last one before August is out:
Metalfish has gone to tempered glass:
It looks like they took the Metal Solid mATX version and removed the U1 power supply and added two fans to the front. The fans are all 92mm (2 on top and 2 in front). 3 low profile slots, and its a bit wider than the Metal Solid so I assume it can get more than 60mm CPU clearance than the Metal Solid.
I'll try to order one this week, i'm not sure if it's on sale yet or maybe it just went up this week.
I'm currently in the early stages of designing a case that will likely have a patentable feature. If I do end up patenting, I'm not going to bother doing it in North America/Europe/etc., I'll do it in China.
Very interested in both of these cases - they remind me of CustomMod's Mini ITX design. Does anyone know what restrictions they place on the graphics card?
He's talking about the ZS-A4M, not the ZS-A4. I think for the ZS-A4M it's 190mm.For the 1U A4 I think its 210mm and for the ZS-A4 its 300mm in length.
@Ganelon can I ask how you find these on Taobao? Any special search terms? If I search for "ITX chassis" using that site, there are lots of results for motherboards/etc. that aren't cases.
Or just search with this term without quotes "itx机箱"
I like this case they have that is based off the DanCase A4. they have a small space for thin fans below the motherboard, I think its very smart! Push all the hot air out the top. If you go to view it you can view user comments about the product and its filled with pics and happy buyer.
I wonder if there is a way to get instructions on how to put this together? Or is it pretty much a guessing game? anyone know?
