Other What's on Taobao
Windfall
2,117
1,584
Correct me if I'm wrong; cloning such cases until it reaches the quality of original will be quite costly, such that the price of each will rise close to the original?
This is very true.
No need to hope at all. Right up on the top, the first 2 words (in green) of the title mean ''I will buy it for you'' (my paraphrase).
Actually, near the bottom of the page, it spells everything out so clearly.
They are just a reseller. They buy an item from an official channel and then sell it to you. The technical name is 'Delegated purchase' or simply an agent (like Superbuy).
Ah, thanks for clarifying!
ababa
60
Nice! Thanks for sharing! Seems you faired better in customizing through superbuy. Hopefully you can get your ideal case. I am still on the edge on whether to buy another case or just upgrade to a better low profile cooler, like the recent AXP90 Cu. My L9i couldn't keep my r3600 cool enough.
How goes your 3600 temps?
I am planning to build components including 3600
That's my dream SFF case, plenty of rooms for a wider and taller cpu cooler, unfortunately, seller seems to be away
prayogahs
236
343
Quite warm with L9i. Idle temps ranges between 50-55C but easily spikes to 60-70C when just doing light tasks as that is how the Ryzen CPU works. It makes the fan ramping up and down which is a a bit annoying. While gaming it usually at 70-75C, Cinebench will raise it to a toasty 85C and Prime95 will make it hit temp limits at 95C and throttles. The ASUS bios is also annoying compared to my previous AsRock board as the critical temp is only at 75C and I cannot increase it in the BIOS manually so the fan will run close to 100% most of the time at that temp. Hence looking for better low profile coolers or changing to a bigger case to fit tower coolers.
raksan
41
55
My 3600 also idle around 50-55C. I have used Jonsbo hp400, Jonsbo+Noctua fan, Cryorig c7 copper, C7Cu+120 mm noctua fan. The Cryorig C7 copper+120 mm fan is my best combo so far, and also under volt by 0.10v help cool the cpu a bit. I have Formula Loli 2s case (182 X 114 X 220 mm).
Reactions: prayogahs
ababa
60
Yeah, thats another option. Will look at those cases. Thanks.
Metalfish S5 looks good as well, dunno about case quality overall
Maybe less ''premium'' than sunmilo but price is insane, 359 RMB and it has enough room for an 135 mm CPU Cooler^^
prayogahs
236
343
My 3600 also idle around 50-55C. I have used Jonsbo hp400, Jonsbo+Noctua fan, Cryorig c7 copper, C7U+120 mm noctua fan. The Cryorig C7 copper+120 mm fan is my best combo so far, and also under volt by 0.10v help cool the cpu a bit. I have Formula Loli 2s case (182 X 114 X 220 mm).
Nice, whats your temps? I bit the bullet and bought the new AXP90 Copper just to try.
Yeah I know that case. Quality should be meh. I have the Metalfish S3 and its so-so but thats a given at that price.
ababa
60
Do you have any dent, scratch from the case itself?
I got Jonsbo cases and every time, cases look perfect with no sign of any imperfection
However its a model within 50-80$ lol
prayogahs
236
343
Visually its fine without any scratches or dents, but the panels needs a bit of pushing and aligning the screws to fit them in as its slightly misaligned. Still acceptable though considering the price.
Vonwilbur
If anyone is interested, I contacted the seller of the ZS-A4 through superbuy and he said he will offer color customization on the ZS-A4 V2, it will just take a little longer.
prayogahs
236
343
Hi guys, just want to share my own list. This is just for my own reference and I thought it might help others. Not all info are accurate, either due to subpar translation or not enough information like with swapping certain components or limitation if using a larger GPU or PSU. If in doubt, please do your own research or contact the seller as some specifications might be outdated.
EDIT: Added other cases
Sam
25
Hi guys, just want to share I own list from what I found here. This is actually just for my own reference and I thought it might help people here. The cases listed here are all M1/classic layout without riser. Not all info are accurate due to subpar translation and please do your own research as its missing incompatibilities with swapping certain components or limitation if using a larger GPU or PSU so please take it only for reference. If in doubt, please contact the seller as some specifications might be outdated.
EDIT: Updated table to include various sandwich and flex psu cases as an overall picture. Sorry in advance for any mistakes/inaccuracies
SellerCaseStyleCase Length (mm)Case Width (mm)Case Height (mm)Volume (L)Footprint (cm2)Side PanelCPU Height (mm)AIO supportGPU Length (mm)GPU Width (mm)GPU Height (mm)MotherboardPSUStorageCase FanPrice (CNY)
Captain S.Captain S. V1Classic34214925212.84509.58Glass/Alu126N/A33011550ITXATX2.5x5 / (3.5x1+2.5x2)80x2+12025x2 898.00
Captain S.Captain S. V2Sandwich31814025111.17445.20Glass/Alu62240mm30713345ITXSFX/SFX-L2.5x212025x3 899.00
Captain S.Captain S. V3Classic32816527414.83541.20Glass/Alu140N/A?13260ITX / MATXSFX3.5x1+2.5x29025x1 + (12015x1/14015x1) + 12025x2 969.00
Captain S.Captain S. V6Sandwich1881422677.13266.96Glass/Alu67N/A178?45ITXSFX/SFX-L2.5x412015x1 799.00
CriticalCritical cp-oneSandwich3331202007.99399.60Aluminium48N/A32014640ITXSFX3.5x1+2.5x28015x2/9015x2 710.00
CriticalCritical cp-threeClassic33315724913.02522.81Aluminium138N/A327?59ITXSFX?? 399.00
CriticalCritical cp-twoSandwich33314424011.51479.52Acrylic/Alu53240mm327?59ITXSFX2.5x212015x1 + 12025x2 399.00
Deng StudioDeng F12Classic33216725013.86554.44Acrylic/Glass135240mm32013055ITXSFX2.5x4 / (3.5x1+2.5x2)80x1 + 12015x3 1,259.00
Deng StudioDeng F15 ProClassic33219829719.52657.36Glass165240mm320?60ITX / MATX?SFX/ATX(140mm)(2.5x6/3.5x3) / (2.5x3/(3.5x1+2.5x2))120x1 + (120x2/140x2) 1,479.00
Deng StudioDeng M25Classic37019834024.91732.60Glass165240mm+280mm??60ITX / MATXSFX/ATX3.5x2 + 2.5x29015x2 + 120x3 + (120x2/140x2) 1,759.00
Dream CaseDream D1F-IClassic2701552209.21418.50Steel/Acrylic135N/A27014847ITXSFX/SFX-L2.5x280x1/90x1 218.00
Dream CaseDream D1F-MClassic33015528514.58511.50Steel/Acrylic135N/A33014860ITX / MATX(250x250)SFX/SFX-L2.5x2 + 3.5x180x1/90x1 + 120x4 280.00
Dream CaseDream D1FXSandwich3101201806.70372.00Steel/Acrylic50N/A31012547ITXSFX2.5x1N/A 310.00
Dream CaseDream D1USandwich2401102205.81264.00Steel/Acrylic38N/A240?47ITXFlex2.5x2N/A 188.00
Dream CaseDream D1U-20Sandwich2001102405.28220.00Steel/Acrylic38N/A200?47ITX / DTX(190x170)Flex2.5x28025x2 188.00
Dream CaseDream D1U-240Sandwich31513026010.65409.50Steel/Acrylic55240mm31014850ITX / DTX(190x170)SFX2.5x112025x2 350.00
Dream CaseDream D1U-27Sandwich2701302408.42351.00Steel/Acrylic47N/A270?50ITX / DTX(190x170)Flex2.5x212025x2 208.00
Formula CaseFormula Loli 1Sandwich?????Acrylic/Alu48N/A??40ITXFlex2.5x39015x2 397.00
Formula CaseFormula X1Sandwich3101341827.56415.40Aluminium65240mm /w top hat30412545ITXSFX/SFX-L2.5x612012x1 + 12025x1 + (12025x2 /w top hat) 1,388.00
GeeklabNano3Sandwich1861042354.55193.44Acrylic/Alu42N/A180?40ITXFlex2.5x2 (9mm)8010x2 387.00
GeeklabNano3cSandwich1861062364.65197.16Wood43.5N/A180?40ITXFlex2.5x2 (9mm)8010x2 109.00
GeeklabNano3PlusSandwich1911132435.24215.83Acrylic/Alu49N/A185?40ITXFlex2.5x2 (9mm+14mm)8015x2/9015x2 427.00
GeeklabNano3SSandwich1761002203.87176.00Acrylic/Alu40N/A175?40ITXFlex2.5x2 (7mm)4010x1 427.00
GeeklabNano4 ProSandwich2041142365.49232.56Aluminium50.5N/A198?40ITXFlex2.5x38015x2/9015x2 598.00
LZmodLZ-A4 T31Sandwich3161272138.55401.32Aluminium50.62N/A31013850ITXSFX/SFX-L2.5x48025x2 718.00
Mechanic MasterMechanical Master C24Classic2491552499.61385.95Glass/Alu130N/A24513060ITX / MATX(225x175)SFX2.5x4 + (3.5x1/2.5x2)8015x2 + 9025x1 + (8025x2/12025x1) 599.00
Mechanic MasterMechanical Master C26Classic31515526512.94488.25Glass/Alu130240mm31011860ITX / MATXSFX/SFX-L2.5x4 + (3.5x1/2.5x2) + (3.5x2+2.5x2)90x3 + 12025x2 829.00
MetalfishMetalfish G5 PlusSandwich32014026011.65448.00Acrylic/Alu60N/A300?40ITXSFX/SFX-L2.5x212025x2 399.00
MetalfishMetalfish S3Sandwich2001052505.25210.00Alu/Acrylic/Glass40N/A195?40ITXFlex2.5x1 + (3.5x1/2.5x2)8010x1 299.00
MetalfishMetalfish S3 PlusSandwich2401402809.41336.00Glass/Alu70N/A230?40ITXSFX/SFX-L2.5x412025x1 379.00
MetalfishMetalfish S5Classic30016026012.48480.00Glass135N/A29013260ITX / MATX(245x220)SFX/SFX-L2.5x1 + 3.5x290x3 + 120x2 359.00
Seven.CMESeven FL-A4Sandwich3151402109.26441.00Aluminium50N/A30814054ITXSFX/SFX-L2.5x312015x2 588.00
Seven.CMESeven M1 (10.8L)Classic31715522010.81491.35Aluminium125N/A30811240ITXSFX/SFX-L(2.5x2+3.5x2) / 2.5(7mm)x8 / 2.5(14mm)x490x3 658.00
Seven.CMESeven M1 (12.8L)Classic31716524512.81523.05Aluminium135N/A30814268ITXSFX/SFX-L(2.5x2+3.5x2) / 2.5(7mm)x8 / 2.5(14mm)x490x3 + 12025x2 658.00
Seven.CMESeven SL-A4Sandwich31514025011.03441.00Aluminium50240mm30814054ITXSFX/SFX-L2.5x312025x2 628.00
SGPCSGPC K29Console190404003.0476.00Aluminium30N/A180?43ITX / MATX(226x185)Flex2.5x4N/A 289.00
SGPCSGPC K39v2Sandwich1801002203.96180.00Aluminium47N/A180?43ITXFlex2.5x2N/A 179.00
SGPCSGPC K55Sandwich3041161746.14352.64Acrylic/Alu55N/A30513443ITXSFX2.5x2N/A 269.00
SGPCSGPC K66Classic1901602306.99304.00Glass55N/A19013360ITX / MATX(226x190)ATX2.5x1N/A 229.00
SGPCSGPC K77Classic2701502108.51405.00Glass135N/A27013850ITXSFX2.5x38025x2 299.00
SGPCSGPC K99v2Sandwich3101302409.67403.00Glass/Acrylic/Alu65240mm30514043ITX / MATX(226x190)SFX2.5x312025x2 359.00
SKTCSKTC Q1Classic27719025413.37526.30Alu/Acrylic/Glass160120mm26014840ITX / MATX(226x175)SFX/ATX2.5x2 + 3.5x1120x1 239.00
SKTCSKTC Q2Classic30019328516.50579.00Alu/Glass160120mm270?60ITX / MATX(240x195)SFX/ATX(3.5x1+2.5x1) / 2.5x3120x2 219.00
SKTCSKTC S02Sandwich32014228512.95454.40Tempered Glass & Alu55240mm305?40ITXSFX(3.5x1+2.5x1) / 2.5x212025x2 499.00
Small CaseBs2 (Air)Sandwich3201382109.27441.60Aluminium62N/A29812542ITXSFX2.5x212015x2 1,339.00
Small CaseBs2 (Water)Sandwich32013824810.95441.60Glass/Alu57240mm29812545ITXSFX2.5x212025x2 1,169.00
Small CaseSmallest OneClassic2801492128.84417.20Acrylic/Glass/Alu125N/A26811240ITXSFX/SFX-L2.5x4 / (3.5x1+2.5x2)80x1/60x2 1,138.00
Sunmilo StudioSunmilo C01Classic28018523512.17518.00Glass160120mm277?40ITXSFX/SFX-L2.5x2120x1 899.00
Sunmilo StudioSunmilo C01sClassic28016023510.53448.00Glass135N/A277?40ITXSFX/SFX-L2.5x180x1/90x1 899.00
Sunmilo StudioSunmilo S01Sandwich1961302726.93254.80Aluminium56N/A190?40ITXSFX/SFX-L2.5x312015x1 739.00
Sunmilo StudioSunmilo T03Sandwich32013025210.48416.00Glass/Alu & Glass56240mm31013049ITXSFX2.5x212025x2 839.00
Ultra CivilzUltra Civilz A4FSandwich3081392159.20428.12Aluminium/Glass?68N/A300?45ITXSFX2.5x39015x2 + 12015x2 999.00
Ultra CivilzUltra Civilz A4F-PYSandwich3061432159.41437.58Aluminium/Glass?76N/A300?45ITXSFX3.5x1 + 2.5x39015x2 + 12015x1 869.00
Ultra CivilzUltra Civilz A4F-XLSandwich30813924010.27428.12Aluminium68N/A30015845ITXSFX/SFX-L2.5x212025x4 999.00
Ultra CivilzUltra Civilz A4sSandwich30813526010.81415.80Tempered Glass68240mm300?45ITXSFX2.5x39015x2 + 12025x2 1,199.00
Ultra CivilzUltra Civilz M1Classic31822516011.45715.50Aluminium/Glass?138240mm310?58ITXSFX3.5x1 + 2.5x380x1/90x1 + 120x2 969.00
Warhead DesignWarhead Dual CoolSandwich25013037012.03325.00Aluminium502x240mm32015060ITXSFX2.5x212025x2 1,599.00
Warhead DesignWarhead MicroSandwich3151292309.35406.35Aluminium55240mm300?52ITXSFX2.5x212025x2 899.00
Warhead DesignWarhead NanoSandwich2351292206.67303.15Aluminium55120mm230?40ITXFlex2.5x412025x1 799.00
Warhead DesignWarhead PapyrusSandwich2771301957.02360.10Aluminium110120mm/240mm195??ITXSFX2.5x36025x2 + 12025x2 599.00
Warhead DesignWarhead Sans L (A)Sandwich?????Aluminium60120mm/240mm31515045ITXSFX3.5x1 + 2.5x212025x2 499.00
Warhead DesignWarhead Sans L (B)Sandwich?????Aluminium50120mm/240mm31515059ITXSFX3.5x1 + 2.5x212025x2 499.00
Warhead DesignWarhead TorielClassic28218527214.19521.70Steel130N/A27515040ITX / MATXATX3.5x1 + 2.5x28025x2 + 12025x4 499.00
天狼星机箱Nova1024/T20Sandwich3081362048.55418.88Acrylic/Glass/Alu55N/A30513050ITXSFX2.5x39015x3 382.00
天狼星机箱RDX1024/T30Sandwich31914025011.17446.60Acrylic/Glass59240mm31216549ITXSFX/SFX-L2.5x112025x2 570.00
天狼星机箱T10Sandwich226112.5252.86.43254.25Aluminium43N/A220?40ITXFlex2.5x19015x2 372.00
天狼星机箱T50Sandwich32414822110.60479.52Acrylic/Glass61N/A30312955ITXSFX/SFX-L2.5x39015x3 307.00
小白DIY电脑机箱DIY A4Sandwich3061262208.48385.56Aluminium52N/A29012042ITXSFX/SFX-L2.5x29015x2/12015x1 829.00
机械库JXK-F1Classic32015723711.91502.40Alu/Acrylic136N/A31513560ITXSFX3.5x1 + 2.5x260x2 399.00
机械库JXK-J1 (Motif clone)Open?????OpenOpen120mmOpenOpen40ITXSFX/ATXN/AN/A 699.00
深蓝SLSL-A4+Sandwich3361312129.33440.16Glass?49120mm320?40ITXSFX2.5x440x3, 60x2, 80x2, 120x1 740.00
深蓝SLSL-M1Classic33516823813.39562.80Acrylic140240mm32013060ITX / MATX(225x175)SFX/SFX-L2.5x2 + (3.5x1/2.5x1)80x2 + 120x1 799.00
祖传黑店ZS-A4Sv2Sandwich2741151946.11315.10Aluminium49N/A26914042.5ITXFlex2.5x48010x2? 760.00
祖传黑店ZS-A4v2Sandwich3161291857.54407.64Aluminium48/60N/A31114142.5/54.5ITXSFX/SFX-L2.5x2N/A 850.00
老K机箱定制Cube X1Sandwich31013824010.27427.80Alu/Acrylic55240mm30013554.5ITXSFX2.5x312025x3 799.00
老K机箱定制Cube X1mSandwich3101382008.56427.80Alu/Acrylic65N/A30013544.5ITXSFX2.5x312015x2 + 12025x1 769.00
老K机箱定制K01Sandwich3101131856.48350.30Glass & Alu/Alu49N/A30213540ITXSFX2.5x2N/A 778.00
老K机箱定制K02Sandwich3151302409.83409.50Glass55240mm30614054ITXSFX2.5x312025x2 689.00
老K机箱定制K03Classic2821472289.45414.54Glass125N/A27511246ITXSFX/SFX-L2.5x3N/A 789.00
老K机箱定制Nano S1Sandwich1821012364.34183.82Aluminium39N/A175?40ITXFlex2.5x28010x2 588.00
魔神科技电脑机箱城Ghost S1 (clone)Sandwich3101371867.90424.70Aluminium63240mm /w top hat30412545ITXSFX/SFX-L2.5x312025x2 /w top hat 598.00
魔神科技电脑机箱城HGL A4Sandwich32014026011.65448.00Tempered Glass & Alu55240mm31013548ITXSFX2.5x2120x2 698.00
魔神科技电脑机箱城MiniSandwich2001202506.00240.00Aluminium45N/A18514545ITXFlex2.5x28015x2/9015x2 299.00
魔神科技电脑机箱城MS4Sandwich26016033013.73416.00Aluminium115N/A25014050ITX / MATX(245x245)SFX2.5x38015x2 + 12025x1 388.00
That's an excellent list you put together!
N4nier
I have a question that may seem dumb, but I'm just trying to figure it out. If I didn't get the PCI-e riser cable that was recommended for the cases I bought off tabao, are they all the same? If I know the lenght can I just buy one off amazon?
Thanks guys.
DKsystem
79
140
Thanks guys.
Technically yes, it will work. But those screw holes fixing itself to the chassis have no standards, so you might want to check them before you buy one.
prayogahs
236
343
Just replaced my L9i to the AXP90 Cu to cool my R5 3600 in the DSE Breathe and dropped my idle and load temps around 5-10C. Originally my idle temps was at 50-55C and now its closer to 40-50C. Load temps under Cinebench was 85-90C but now it was 80-85C peak when finished. Prime95 immediately reach thermal throttle at 95C with L9i but now it manages to hover at 92C for a while until it reached thermal throttle anyway. I didnt swap the fan yet as its decent but a bit louder than the noctua. I dont have the Cryorig C7/C7G cooler for comparison so others may have more info. Good impression overall.
Cross posting my experience with the Thermalright AXP-90 Copper here as I got it from Taobao
