Watercooled DanA4 Case? - 240SFXL
Questors
124
82
Side plates are translucent tempered glass, and I even have coated mirror glass.
I was referring to the framework as well as front and back panels. If it is indeed aluminum, great! To be clear, I wasn't bashing the product, at least not intentionally. I was however cautious about the claims.
Is the aluminum thin, less than 2mm or is it 2mm or more in thickness?
sunmilo
33
Except for glass, everything else is aluminum.
Front panel 4mm thickness, other 3mm.
Reactions: Questors
Kyuss
Beatiful case! I have some questions:
1- It supports GPU watercooling? I have an EKWB Predator and a block for my GTX1080Ti.
2- It supports SFX-L? I fit does not, could it be modded to do so?
PS: Could you put all the case specs in english in some place please?
Damascus
553
395
This isn't OP's case, and the seller almost certainly isn't on here. As for the first question, it will support you watercooling bui a pheonix ste will absolutely need it's tuning shortened, and the rad might be too long.
It can probably take sfx-l as well, given that sfxl is part of the name. Use Google chrome translation to assist on the taobao page
Reactions: Kyuss
Kyuss
Thank you!
(I figured out what you are saying in some phrases:
As for the first question, it will support watercooling, but a phoenix MLC will absolutely need it's tubing shortened, and the rad might be too long.)
THX again
