Nice pricing, what location do the 3x92mm fans mount at?
If it pains you to design a case this big Michael, I shudder to think how you felt designing my case! Since it's double the volume haha
Nice case man, I like the PSU mounting system
This makes this case future proof, adds more space on top maybe even to mount 120mm fans, so sir, you might have the solution many of us are looking for, affordable and well designed case, as pointed out before.I will do the same for others to see.
How about this?
Keep graphics card clearance at 295 mm, make this case 20 mm wider, and give users the option to move the motherboard tray. One position provides enough space for a 70 mm tall CPU cooler and dual slot graphics card. The other provides enough space for a 50 mm tall CPU cooler and triple slot graphics card. This may also create enough space for the 3x 92 mm fan mounts to be replaced by 2x 120 mm fan mounts. New volume would be 7.9 liters.
This is a concept that I will be exploring with the Velka 3, with 1 and 2 slots instead of 2 and 3. You can read a little bit about it here: https://smallformfactor.net/forum/t...p-to-8-cores-and-gpus-up-to-rtx-2070-4l.9681/
How about this?
This is starting to sound like SideArmD's solution. I agree, in the current generation of cards, this seems like the best way to handle it.I will do the same for others to see.
How about this?
Both cases are approaching the problem with very different case designs. I like them both.
@Thehack have cards ever decreased in size before? Now that they have factories producing cards of this size, what are the chances they will do a 180? For the mainstream, larger coolers run cooler and quieter (normally).
@Thehack Thank you for the long reply. I appreciate the detail.
The case I really like is 2 slot and ITX, which is why I haven't purchased it yet. I worry when I look at the current trend of GPU size.
love the pricing and how it looks
but dang my gpu doesn't fit by 1mm.
Should I try using a sandpaper to shorten the plastic shroud?
The purpose of this case will be to offer a compact solution for housing common components such as an SFX power supply, full sized graphics card, and 50 mm CPU cooler in a anodized aluminum chassis.
The layout is nothing new, featuring the same back to back layout found in the Dancases A4-SFX. However, it will feature a unique internal structure.
-power supply mounted onto 4x 16 mm aluminum standoffs, supported by motherboard tray, front panel, and side panel on all sides. This allows the power supply to exhaust air through the bottom of the case through an opening, and allows the user to access the back switch of the power supply without opening the case.
-power supply cable routed through the bottom without cable extension. This is a cost saving feature that also helps reduce the height of the case while making space for a extra top panel fan. Power cable will need to be zip tied to rectangular openings at the bottom of case and routing through the back panel.
-motherboard tray mounted at two points in the bottom, one point in the back, and one point in the middle of the case with aluminum standoffs to the side panels for increased space efficiency.
-precisely placed expansion card slit: to keep graphics card in place without additional parts
-standard length motherboard standoffs for compatibility with M.2 heatsinks on the back of the motherboard
Dimensions: 200 (H) x 298 (L) x 111 mm (W)
Volume: 6.6 L
Weight: 0.9 kg
motherboard: mini-ITX
power supply: SFX
expansion card: 2 slots (45 mm wide), 295 mm / 11.6 in long
CPU cooler: 52 mm
storage and cooling options: (top of case)
1) M.2 + Three 92 x 25 mm fans
2) M.2 + One 92 x 25 mm fan + one 3.5" drive / one 2.5" drive
3) M.2 + Two 2.5" drives
power button: preinstalled mechanical button, replaceable with any 16 mm button
riser compatibility: LiHeat 300 mm D type or VELKASE riser
Materials:
motherboard tray: 1 mm powder coated steel
Back and bottom panel: 1.2 mm or 1.5 mm powder coated aluminum
front and top panel: 1.2 mm or 1.5 mm aluminum
side panels: 1.5 mm sandblasted aluminum
with riser: $119.99
without riser: $99.99
shipping to United States: $19.99
shipping worldwide: $39.99
Kickstarter: No
Release date: TBD
Top: brushed aluminum
Bottom: sandblasted aluminum
