Enclosure Thermaltake Core G3: a 24L ATX case with SFX mount
br1p
25
Do you think that this case could be carried in a backpack? I am looking for an atx casing to be able to move and I do not find many options
6,127
5,032
Belgium
You'd need a very oversized backpack, I don't know if that's an easier to find solution than smaller ATX case.
TheHig
951
1,171
Cincinnati, Ohio
I’ve had a G3 for a while and have been using it off and on as a secondary box or parts catcher to test used parts.
Anyway, I put my ATX board back in service as the stationary main system and went back to the G3 because it’s easy to build in and I like the way it looks with the side panel off. Also owning an X570 motherboard right no is worth more than toilet paper apparently ?.
Bonus custom CPU loop because why keep shiny WC parts in a drawer right?
Ellimist
37
39
I just finished building and setting mine up. I still want to get some custom PSU cables and I want to get a top fan some unicorn puke and shorter PCIe FLEX cables. I'll get some thin liheat ones so I can use dual SLI cables.
