pcm
I hate you. :p Just checked and out of stock again.
Hi Gallahant. Sorry to hear you were unlucky again.
Basically I checked every 30 mins on my mobile for the last few days. Every so often a small batch appears to come available for whatever reason.
Last night it was approx. 9:30pm (UK time). They appeared to have sold out by 11:30pm (ish).
Which colour are you after?
Beardedswede
191
158
If I would order one now, when would it ship? I really want this case :D
if you get one when they release one or two on the website at random times, yeah I would guess you must get a spot in the first batch so they should ship it off in the end of september .
D
Deleted member 8605
Guest
End of september? :eek: wow, ok, I need to prepare myself for that XD Ok, let the sniping begin.
Bangle
147
112
you need to check if it fits, if it fits then it should be fine.
A GTX1080Ti FTW3 fits, and these are one of the biggest cards available. I'm sure a reference Vega 56/64 will fit. Louqe have a GPU compatibility list on their website.
Beardedswede
191
158
I don't think there are any oversized blower style coolers available nowadays (and there may never have been any), so I'd be very surprised if it didn't conform to the regular old 2-slot width, with the other dimensions matching up with a stock-size PCB.
Probably true but it’s also a hight clearance issue. Some cards are taller and/or have connectors high up making a L power connector needed or a small top hat.
lawney
106
68
Not reference blower coolers. And are there any consumer cards with power at the end? Usually that’s only workstation cards. And consumer cards have power on top.
deadline
161
67
Bergen, Norway
Sure, I can't see why not. Any blower style cooler should do well in this (and pretty much any other) case.
Thanks! I'm not too worried about size (I've checked it will fit), but more worried about potential heat issues. These are, after all, some of the hotter (literally) cards on the market. Any advice on how to best deal with that?
Beardedswede
191
158
you can always buy a small or medium tophat to add more fans, if needed, not sure how much that will help but im sure you can do some testing with some fans if you get heat issues.
Reactions: deadline
deadline
161
67
Bergen, Norway
I was actually planning to get a large tophat for watercooling the CPU (Ryzen 7), and I'll get a Kraken 52 as recommended by Jayz. Will this benefit my whole system? I'm quite new to PC-building, and certainly to the SFF scene.
Tack!
