It only has the pull tab on the top. So unless you modded it that’s your only way of getting into the case. without the pull tab you won’t be able to move the two sides therefor blocking access to the internals.
faggan is engeniring this top hat/ reservoir/ pump mount for this case.
this is thick enough if you are ok going custom loop
btw the new eta is early september
How can it be screwed in? I thought it relied on the pull tab on the top of the grill.it will be possible to screw in the top grill
Yes!Ooo. I love how you missed and matched the to grills. That limestone case was awesome. The limestone case with the copper top is even better, but that green case with the copper top is a work of art.
There are 8 screw holes in the 4 corners of the tophatsHow can it be screwed in? I thought it relied on the pull tab on the top of the grill.
Can you upload that image somewhere else? Can't see slack images unless you're on the slack.
that's very cool. May be useful for my ghost s1 glass tubing loop. I already have a comboblock from brian on this forum coming in soon but this would be a great addition to my build.
It has 4 holes in each corner for screws - by the looks of it.It only has the pull tab on the top. So unless you modded it that’s your only way of getting into the case. without the pull tab you won’t be able to move the two sides therefor blocking access to the internals.
Ash with the limestone grill looks sick.
I just ordered the custom copper grill separately to my original order of the Ash case (intending to spray it white) and i've asked them if they can add it to my shippment. When the reply i'll ask them about the next lot of pre-orders.Does anyone know when the next batch will be available to pre-order. I want to spend my money!!![]()
Thanks for the correction.It has 4 holes in each corner for screws - by the looks of it.
I just recieved email from louqe, shipping is pushed back again to September ..
yeah they adusted the tophats, 1mm higher, and that became a bigger problem then exspected. They are a to much of perfectionist sometimes, at some point you need to push the changes to the next version.I just recieved email from louqe, shipping is pushed back again to September ..
