Good morning and first of all the greatest of respect for the attention to detail you demonstrate with the development and production of the gorgeous Ghost S1 and that you are sharing it this outspoken with us.
The drawback you as a designer have when dealing with enthusiasts like the people in this forum is that no matter how much attention to detail you invest into your product, there will always be someone who wants an adaption to it because use cases and esthetic preferences are just as manifold as people in the world.
Sadly I am no exception to that but would like to emphasise that, at least from my side, this should not come of as nitpicking but conversely should be a testament for the appreciation of your work and that I consider it a very attractive starting point that deserves every thought I spent on envisioning which changes to it would make it my ideal.
I would love to support the work of your company with an order but since Ghost S1 is aimed at a different target group it's not suitable for the build I have in mind and also too expensive.
To not further bore you, I would therefore like to ask if you plan to utilize the knowledge and milling capabilities you gained thanks to the development of Ghost S1 to eventually extend your product range to serve customers who have an use case that doesn't require a dGPU but that is already covered by the newly released AMD Raven Ridge APUs?
In my opinion that use case would offer the freedom to some changes in the design that would be beneficial for both you and the customer base including:
- Non perforated side elements to further streamline the looks and reduce milling costs
- Simplified inner structure to reduce costs of manufacturing and purchase of extension parts and a potentially improved (vertical) airflow that allows for (a) very slow rotating fan(s) which will further reduce the noise level of the PC
- Possibility to use small wattage non standardized PSUs to increase the power efficiency in the standard use case of 20-120W, cut costs and possibly further decrease the case size
- Cater to a new audience who can’t or doesn’t want to afford a 2000-2500SEK/200-250€/$250-300 case for hardware builds of only around twice the price of the case but might be willing at a price of up to 1500SEK
