Ghost is compatible with Corsair Dominator RGB DIMMs and the Asus ROG Ryuo 240mm AIO!
That build is just incredible! True inspiration.Check out this build just posted on [H]ard, fully water cooled Ghost S1 with hard tubing. This thing is way, way too cool.
I found this video on Reddit when I was looking at custom cables for my Ghost. Thing I found interesting was the cooler setup this guy is using. He has a bottom mounted medium tophat with a 120mm AIO mounted with a slim Noctua fan, he put it on the PSU side so the fan sits in the cutout under the PSU.
Indeed an interesting use of the space and also with the AIO in the buttom. I have been thinking this must be a good way to pull in fresh air even to an 240 mm AIO in a tophat (placed in the buttom). Something I wanted to try out myself.
It seems he has also added some larger feet to create a bit more space for airflow.
Sounds like he tried to paint it. Failed and sold it. They never shipped anything in white.Did Louqe sell the Ghost S1 with any color top grills other than black, nickel, or copper? I purchased a second-hand Ghost S1 in pangaea, and its grill is white. The seller claimed it came that way, but the paint job looks a little shoddy (it's very uneven, and there are scraps with copper showing through).
There is no white top grill option on their website currently.
This guy definitely painted his top grill. I did receive a defective top grill and I was planning to have it painted (I do have an airbrush system). However, After building the case, I found there's literally no gap between the side panel and the top grill. So I gave up my plan and RMAed my top grill.Did Louqe sell the Ghost S1 with any color top grills other than black, nickel, or copper? I purchased a second-hand Ghost S1 in pangaea, and its grill is white. The seller claimed it came that way, but the paint job looks a little shoddy (it's very uneven, and there are scraps with copper showing through).
I did the exact same thing and I found with side panel removed, my 8700k with L12 runs 10 degree C lower than the temperature with the side panel.I have some new case feet coming today, I am sure the ones included with the Ghost are too low to provide much airflow.
currently I do not have any tophat installed. but when I put the tophat on as exhaust it does absolutely nothing to the temperature with my L12 blowing air down to the CPU. So, since the L12 get the air straight from the side panel then I believe neither the intake nor exhaust fan at tophat will help temperatureDo you have a top hat with exhaust fans? If I was sticking to air cooling in mine I would go that route.
So you have the res in the bottom section :S hmmm
Ye i know, it seems to kill the point of the res in the radiator when having it as the lowest point of your loop tbh
Oh I totally agree, I wanted to have at the top but it is 2 mm too tall for the top hat and the top panel won't fit properly. It works at the bottom though.
Yee, i just bought the exact same radiator for my custom loop rebuild!
Im gonna place it on top with 15mm fans then it Will fit like a glove ?
Nice, I might give that a try. Make sure and post some pics.
