The space inefficiency thread
The_Crapman
Halesowen
I'd been told you folk here might like this.
It'll get fuller, honest!
Arboreal
874
877
57
Sunny Bournemouth, UK
Hi Crappy, good to see you over here; although your setup currently looks 'bad', that white monster at 154 litres is a LOT of volume to contend with.
Guille, not bad, but again, 154 litres is gonna be hard to use efficiently whatever you load it with!
D
Deleted member 18
Guest
@W1NN!NG: there are quite a few ATX cases which I wish were available in ITX size. Fractal just announced a mATX version of their Meshify e.g. which they should have just shrunken down to ITX size.
W1NN1NG
616
532
I agree
Arboreal
874
877
57
Thirded. Case makers still don't scale ITX cases down properly IMHO.
I'm not expecting silly small extreme versions, but not 30+ litres of Evolv ITX (I think I may be able to squeeze an ATX board in mine if I ever get round to attacking it).
Maybe SFX-L PSU sizing and room for a rad - if Dan can do it in 9L in the upcoming C4; surely mainstream cases could do ITX in 15 to just over 20 Litres.
As far as I could see (quick look at a review last week), the mATX Meshify is still bigger than my TJ-08, which isn't really that small in mATX terms at 28L.
AleksandarK
/dev/null
May 14, 2017
703
774
Its not a case, but how do you manage to only fit 4 DIMM slots on an EATX (albiet non-supermicro-EATX-spec) motherboard?
EVGA somehow managed to do it though:
EVGA has had its engineers test the SkyLake-X platform and has detirmined that by reducing the number of RAM channels(and traces going from CPU), the CPU can be overclocked more by 300-600Mhz. There is no reduction in number of channels tho- it still remains to be Quad Channel.
As this is the motherboard made for extreme OC, every Mhz counts.
There are other X299 models with 8 DIMM slots, which serve the purlose of "normal" user.
