The Chimera MachOne: For the pros. Small meets flexible.
VegetableStu
1,949
2,619
what parts/probes do you currently have? o_o not sure how easy is getting a scientific thermometer, and would those fit ._.
or do you have enough parts to run a second motherboard separately that has a t.probe header? o_o
Necere
NCASE
3,300
Necere mentioned the Corsair Commander Pro is an LCD, feels a bit overkill.
That's not what I said. I said you can use something like the Commander Pro, which is a hardware+software solution, or alternatively one of those temp probes with an attached LCD screen. The latter is simpler and cheaper, but isn't going to do anything fancy like graph the temperature.
ATTWIFI
Harmony - why choose between PC and Mac when you can have both.
What is the device that allows for switching between the Mac and PC?
lawney
106
68
What does the top i/o look like in config 1? (i.e. air cooled matx)
What is the max air cooler height in config 1? (NH-U12S? or only NH-U9S?)
How many 3.5" can be mounted on the bottom front in config 1 before GPU interference? Or planned for at all?
Power button?
What were your thoughts about extra i/o as an add-on? I am confused about that.
And if you can manage 5 pcie slots, that would be amazing, and would be a great help for daughter cards in a workstation setting, such as high end video i/o from aja/blackmagic/etc (great for traveling professionals).
Thanks.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Gear 1 compatibility test.
- 2x Noctua 140 + Titan XP + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600
- 2x Noctua 140 + Titan XP + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600 + EK 100 D5
- 2x Noctua 140 + Titan XP + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600 + EK 100 DDC
- 2x Noctua 140 + EK CE 280 Radiator + Titan XP on EK-FC + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600 + EK 100 D5
- 2x Noctua 140 + EK CE 280 Radiator + Titan XP on EK-FC + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600 + EK 100 DDC
- 2x Noctua 140 + EK CE 280 Radiator + Titan XP on EK-FC Rotary + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600 + EK 100 D5
- 2x Noctua 140 + EK CE 280 Radiator + Titan XP on EK-FC Rotary + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600 + EK 100 DDC
- 2x Noctua 140 + MSI1070ITX + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600
- 2x Noctua 140 + EK CE 280 Radiator + MSI1070ITX + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600 + EK 100 D5
- 2x Noctua 140 + EK CE 280 Radiator + MSI1070ITX + X299EITX + i9 7900X + Cryorig H7QL on 2x Noctua 120 + SF600 + EK 100 DDC
gunpalcyril
294
319
I could be wrong, but it looks like he took off the black top plate off the cryorig h7, maybe because its a super tight squeeze. If it is, its a very convenient mod, and should be a great performer for thermals.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Yes, had to remove the plastic cover for it to fit
Reactions: gunpalcyril
