The Chimera MachOne: For the pros. Small meets flexible.
Boil
1,253
1,094
What gear config would permit that?
I believe it would have to be a Gear 1 / ITX for dual 280 rads; Gear 1 / mATX should be able to be done as well, but with a single GPU & dual 240 rads...?
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
mATX with 240 rad in the front + 280 on the side
Reactions: Boil
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
@Wahaha360Also, have you done any testing with dual gpus inside the mach one? Seeing that using two gpus in that case means they will be stacked right next to each other, I'm deciding if I should go for 2x founder's edition 1080's or if I can get away with 2x zotac 1080 mini non blower style cards, for a future build of course.
I’m coordinating with 3lfk1ng now. I’m also interested in two GPU results.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
For dual GPU, if we were to get dual 1070 Strix, is that enough to give an idea for temp testing?
I would buy another high end GPU, but with refresh rumors in Aug, prob better to wait, but I kind of need to test now or I don’t know if I can get the case done in time.
prava
171
259
Not really. Both the 1070 and 1080 are very power-light, so you will never be able to get a real analogy against, say, a GTX1080 TI x 2.
Maybe you should try to get something a bit older, like a GTX980 TI (x2).
