The Breadbox (~2.3L of goodness)
Therandomness
231
270
Here have some minor picture updates:
The top picture is the most recent and correct, the bottom is just for internal layout.
Therandomness
231
270
Ok I have a really dumb idea.
Since it might take a while still to get the case printed (it'll come eventually, don't worry), I am tempted to learn a little bit about PSUs... And design my own, internal one for the case. I know how to get 20V DC from 230V AC with filtering, don't worry about that, but I've been recommended to use MOSFETs instead of transistors (and a 7812 for a reference voltage) to get 12V. However, I have no clue how to do that, so are there any recommendations?
Therandomness
231
270
You could find a power supply that does what you want that you can dissect and reverse engineer :)
I suppose I could :p But in order for this PSU to suit my build properly, I'm either going to have to have it have a 12V and 19V rail (19V for the motherboard, 12V for the graphics card), or just use a boost converter on the 12V rail (though that entails either a second 12V rail or a hilariously powerful single 12V rail). And I have very limited space.
Duality92
307
330
Well if you have a strong power brick that's outputting 19V, you could divide it so that it goes one way to the motherboard and the other to the internal PSU for the GPU?
Therandomness
231
270
Ah, you see, this PSU should internalise all power generating components. I'm aiming to have absolutely no power bricks.
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
Texas
Perhaps a Meanwell PSU would be more inline with your goals?
Regardless, be careful and up-rate your components. :) don't want anything to fail or shock you.
Therandomness
231
270
Right, so, an update (finally lol).
I have decided to make a few changes to the design (once again), most notably now modelling to include an internal PSU. This is mostly for the fact that, well, power bricks are huge and I now consider them to add to the volume. Now, I'll be using the HDPLEX 400W AC-DC and DC-DC combo, and some sort of high-amp boost converter to get the 19V to the motherboard. The new design will be bigger, of course, but I don't see the total volume going over 4 liters. Now, I'm wondering if I should still print (I know, I know, this long and no print!?) the old design to sit next to the new one :p
