LOLOLOL..
That's what I was guessing when you refer to quick connect/disconnects....
It will be interesting to see actual performance improvement...this will be overkill setup (480 external+240X2 internal). Are you also adding another pump in the loop as it will be way larger?
It will definitely be overkill :')
I plan to change my internal layout a bit, getting annoyed with how much room the watercooled RAM takes up. Might just keep the slim Noctua fans for the internal rads and move the 25mm ones to the E-Rad. I will be adding another DDC pump to the external portion of the loop to help with the flow
