2 ways: carefully realign the motherboard brackets or if that doesn't work/it's possible, reduce a connector like I did here:Hey guys I know it was mentioned somewhere can't find it. I put my rtx 2080 in and the hdmi and display port slots are a bit up and my cables are unable to enter as the protection part of the cable will hit the roof
How was this solved
Hi Guys, just wondering, the AIO + GPU side of the case is coolish but the opposite side where its against the motherboard back. its really hot to touch. is this normal?
In terms of temps, everything looks good. Stress testing the gpu goes at like 75 degrees, cpu is 50-60.
Only got really hot when i started doing gpu stress tests. went normal temps it feels luke warm
I have the same, especially when the GPU is under load
Temps seem quite high there.A DA2 build with Asus Z370I and i7 8700K.
Interesting points:-
-Thermalright Silver Arrow 130 Graphene version installed. Read the thread for details of 'conflict'.
-SF600 installed horizontally, leaving space underneath for a 120mm fan.
-a DIY mirror side panel
https://www.chiphell.com/thread-1954606-1-1.html
Ahh alright, well for now my normal temps are 30-40 with no load for gpu and cpu. I have been running realbench for the last 1 hour. The temp is 68-80 for cpu (varied throughout the test, goes up and down, but mostly around 75) and 71-73 for gpu
Ambient temperature is 27-28
I have kraken x52, Have i installed it wrong if im getting these temps on realbench?
Would it be worth trying to flip the airflow direction for the GPU fans?I have the same, especially when the GPU is under load
Oh boy! I am curious about the list!I was considering a dual 240mm radiators loop, but when I added all I need in the shopping cart it came just shy of 700 euros .... nope![]()
I am not sure if his temps are high or not.
I just picked a guy at random, having an i7 8700K at 4.9GHz at 1.28v. He got 79C max with a Corsair H150i pro.
(http://www.tomshardware.com/answers/id-3759638/resonable-temps-8700k-9ghz.html)
So, a Silver Arrow giving a range of 77-84C does not seem so bad at all.
Seems delidded from one picture...Can you tell me @tinyitx is the 8700k delidded? If not those are not bad temps.
I was considering removing the bottom filter-cover and use 2 vertical brackets for the bottom rad and have another on the side, while the pump-reservoir could eventually be fixed on the back if there is not enough space inside.Oh boy! I am curious about the list!
But, wait! a DOUBLE 240mm??? WHERE did you find the space???
Mystery... I have that happen before, but the system crash trying to get 5ghz all cores. I gave up for the night and went to bed. It booted righ up the next day....@Nanook Well just tried turning on the DA2 without doing anything, and it worked???
Damn it! I really don't know which was the cause...
BTW, another test for 1 hour, Prime95+Heaven, 5GHZ OC, AVX 1(!!), RAM OC 3866MHz C18.
In two weeks the GPU water block will arrive!!
Not bad!!! Maybe, with a DDC XRES 100 and one 240mm and 1 120mm, you can have everything inside! And is more than enough! I think the D5 plus mounting bracket/whatever, doesn't fit inside... in depth, but maybe I am wrong!I was considering removing the bottom filter-cover and use 2 vertical brackets for the bottom rad and have another on the side, while the pump-reservoir could eventually be fixed on the back if there is not enough space inside.
Here is the list, fans excluded but you can add the 4 noctuas yourself and you'll go over 700(oh and I didn't add the GPU backplate there as I have one)
