Update 9th August 2019 : Zen 2 Ryzen 7 3800X & a lot of changes
With arrival of zen 2 processor, I've finally made up my mind to switch my Ryzen 7 1700X with a Ryzen 7 3800X, keeping the same motherboard, Asus Crosshair VI Hero (X370 Chipset).
Several factors influenced this choice, but the main one is simple : I just realized lately that this crosshair VI hero has awesome features..
- AUDIO : I own a pair of speakers gigaworks t20 since more than 10 years. I always thought they were quite BS as I always plugged/used them with motherboard audio (mostly mini ITX boards)...since I watched this video :
I was shocked as my speakers sound so badly. I just understood that my speakers were simply badly driven...just a decade after buying them... I plugged them to the C6H...and I was astonished how well they sounded. Afterwards I look at C6H specs and it appears it has a very good DAC ESS® ES9023P.
I'm a bit ashamed especially I love my home cinema setup (marantz amplifier and klipsch speakers)...anyway, from now, I need a good DAC for my audio..
- FAN XPERT 4 : I already tried Asus fan management software back in 2013, 2015 and 2017. Back in 2017, due to R7 1700X temperature offset and awkward temperature monitoring (mainly due to AMD), I switched to Corsair Commander mini to control all my fans. However since 2017, both AMD & ASUS improved and Fan Xpert 4 (even bios setup) is quite pretty good.
Best feature is to link a fan to up to 3 temperatures (either in Bios or in Fan Xpert). Thus for my setup, I put all case fans linked to CPU & PCH (chipset temperature). Tweak is that PCH temperature is directly related to my GPU temperature as it's blowing hot air on Chipset..
Basically as soon as my cpu or my gpu is on load, fans are cooling everything....and at idle, fans can be turned off...
Let go back to my update.
Here is a list of what has been done :
- With Ryzen 7 1700X, update C6H motherboard to Bios 7304 (lastest release)
- Replace Ryzen 7 1700X with Ryzen 7 3800X (no bios update to keep best Agesa so far, 1.0.0.2)
- Remove Front usb 3.0 extension cable. I replace it with an usb 3.0 hub from my keyboard passthrough. More useful in practice, and save a lot of internal space inside Cerberus-X
- Drain, clean, refill my customed AIO (Apogee Drive II and MCR 220 radiator/reservoir combo)
- Replace all Gentle Typhoon AP60 to Noctua NF A12x25. Use full frame grommet on radiator. (by the way, now all my fans are from Noctua..
- Remove Corsair commander mini as it's replaced by Bios and Fan Xpert
- Replace Startech expansion card PEX2M2 with integrated Asmedia pcie/sata controller to Startech expansion card PEXM2SAT32N1 that hold 2 sata and 1 pcie 3.0 4x m.2 slots with 20 cm sata cable. This saves around 10-15sec on bios boot as there is no additional controller to handle. On top of that, it's also better for gpu cooling as new expansion card is smaller, by far.
- Please note than windows 10 is booting after CPU replacement...however it's far from being perfect. Thus I decided to RESET Windows 10 (good news, my licence is still valid)
In terms of performance, I'm simply amazed by Zen 2, Ryzen 7 3800X. Even with my older X370 C6H, it's boosting like a champion!
Here what I experience (stock with RAM XMP profile 3200 CAS 14 loaded) :
- 2 threads : 4.516Ghz
- Gaming (Shadow of the tomb raider, World of Tanks) : just above 4.3Ghz
- Cinebench R20 (all threads) : 4.12Ghz
Basically everything is noticeably faster compared to my former Ryzen 7 1700X : bios boot, windows load, etc...
In my standard usage, CPU is sitting between 4.3 and 4.5Ghz...simply perfect (especially without manual OC)
I've tried to OC RAM and FCLK to 3800Mhz and 1900Mhz. It boots on windows (but it was not perfectly stable)...but I didn't have time right now to tweak more.
Last MAJOR update is NOISE.
My DDC pump (apogee drive II) is spinning at 1200rpm and all others fans are around 200-300 rpm (or even stopped) on idle/low load...almost fanless mode... clearly inaudible/silent. On my previous, Gentlye Typhoon AP60 fans were unable to go lower than 900rpm...not too noisy but not silent.
Even on load, noise remains low as CPU is not OC (not really need it anyway).
At the end, I'm very pleased with my current update...already thinking to my next move..
Here is a gallery of pictures of my build :
