Is it possible to fit a 240mm radiator on the side hinge bracket?
If a rear mounted SFX PSU interferes with it, is it possible to flip the sfx bracket so the PSU mounts closer to the back of the case?
Is it possible to flip the rear mounting for the SFX PSU so that it sits closer to the motherboard than the hinge bracket?Unfortunately no due to the PSU mounting positions. If you mod the PSU mount you can though, but requires a Mini-ITX motherboard.
Nope, rear sfx psu bracket is asymetrical, thus you have only one position to put on case frame.Is it possible to flip the rear mounting for the SFX PSU so that it sits closer to the motherboard than the hinge bracket?
holding out for 3950X?![]()
^ Seriously considered jumping on TR since the 2920x is now 299. Obviously the 2920x is eclipsed by the 3900x but the TR platform is extremely well rounded for a work and play machine for years to come.
Or the rumored Zen2 Threadripper that I've heard some whispers of potentially coming in the Oct/Nov time frame to mirror Intel's HEDT efforts?
I’m aiming to 3900x, especially without smt enabled. 3950x will be too expensive.^ Seriously considered jumping on TR since the 2920x is now 299. Obviously the 2920x is eclipsed by the 3900x but the TR platform is extremely well rounded for a work and play machine for years to come.
That's what i love with Cerberus-X, its flexibility.The Meg Ace looks very good. I was checking out the Gigabyte Aorus Master WiFi for the 3 m.2 slots as well. Looks like these two boards are price competitive. The extra M.2 slot is a no brainier for Cerberus X builds as you can add even more storage with out the cable clutter.
Oh snap. Meg Ace stocked locally with 50 off cpu combo. 3900x is still a unicorn...
Maybe 3600 placeholder for a while ?
Going with the MSI on your recommendation regardless Marc. ?
Yes R9 3900X is still pretty hard to find (maybe next week in France)Oh snap. Meg Ace stocked locally with 50 off cpu combo. 3900x is still a unicorn...
Well MSI X570 is offering same intel nic (211AT) as all competitors + 2.5gbits realtek as all competitors at similar price range (I will test if it makes any differences)While I do often prefer the MSI bios to the gigabyte/asrock alternatives, the VRMs, I/O, and lack of intel nic on the MEG/MPG X570 line is steering me towards either Gigabyte or Asus when the 16-core finally makes its appearance. .
Now question is : who will receive his ryzen 3000 first lolYeah when I make the move I’m set on the Ace. VRM is good enough on all the boards at this price point . I like the look of the MSI board and will give it a go.
