Yes, you should just make sure nothing too hot is touching the wood, you don't want catching anything on fire. Also, most people just go to a metal shop, and it just requires the designs and where you want what to get bent.Dude that case looks sweet. I'm thinking of making my own case too but a small matx version. Is it possible to make a case with wood? I don't have the skill and tools to work with aluminum. Sorry if this is a bit off topic but I'm just curious.
If you use the right type of mounting for the glass, it'll work/ I would recommend some screws if you can't use a screw mount. Screw mount would work the best. Also, what's your native language?Looking forward to see it! @HeroXLazer while u say something about bending, did u think my design will work and is stable enough to hold a glas panel?
Hey guys, do u think a bend like this will work? I am planning to do this with a 20x20x2 mm aluminium L profile. The outer radius is 7mm. The hole is for a screw like this https://www.ganter-griff.de/de/prod...t-Griffen/DIN-464-Hohe-Raendelschrauben-Stahl which holds the glass panel.
I've made a new thread discussing my project if you wanna check it outWood is generally pretty safe for building PCs, a lot of people have built PC desks cases with regular plywood, the ignition temperature of wood is pretty high (~150c to char), similar to acrylic's melting point, and that is for a prolonged period of contact, the actual ignition point of wood is upwards of 200c+
Aluminum sheathing now in one piece. Frame updated.
So is the dark grey section on the side a separate piece or is it part of the outer sheathing?
And it's possible with the right tooling, but be very careful designing an enclose box in sheet metal. Most shops can't form it.
