this is a simple adapter which allows you to mount slim 140mm fans with 120mm fan mounting pattern - e.g. CRYORIG XT140 - to your 280mm radiator
the adapter could be laser cut locally (e.g. SendCutSend or similar services) out of 0.5 ~ 1.5mm stainless steel, aluminum, acrylic or maybe DIY 3D printed
if there is interest from the community I can also make a small batch for you and put it on my shop
I've attached the drawings here - feel free to modify and/or use it for your personal projects
some pictures:
some pictures:
