is it possible to launch a model with a better cooler clearance ?
is it possible to launch a model with a better cooler height compatbility ? or would that be too big for your guys ?
smallformfactor.net
smallformfactor.net
Honestly its because I want to have TWO cakes and eat it as well, I wanted a case both with 70mm or so clearance and a 3 slot gpu, and I actually prefer the Sm580 from it , I do have an m1 right now, and my only wish for it was for it to be a little taller and have a better front io clearance, something I might actually get soon.I'm sure its possible, but with a further increase in width for the 560, the Ncase M1 makes more sense. And as for a wider 580, you're into Cerberus volume territory. If you're looking for a sandwich design with 70mm clearance, there is also the Steck and forthcoming Sidearm.
Thanks for the reply actually , I may get the sm580 anyway or the console cl3 , really liking those casesTwo other cases I have in works are designed for slightly larger air coolers:
SV540 is an SM550 in vertical layout, 2-slot GPUs, but with 75mm CPU cooler height.
Production - Sliger SV590 and SV540 - Vertical SFF Cases!
SV590 18L @ 154mm X 247mm X 472mm - 360MM AIO COOLER SUPPORT (OR 240MM + 120MM) - MOUNTING FOR PUMP/RES IN BOTTOM - 3-SLOT GPU (UP TO 330MM, BIFURCATION SUPPORT) - MINI-ITX MOTHERBOARDS - SFX POWER SUPPLIES - EASY OFF TOP COVER FOR ACCESS TO MOTHERBOARD IO SV540 11L @ 149mm x 189mm x 390mm -...smallformfactor.net
Console layout with 3-slot GPU support (CL3, name TBD) also has 75mm CPU cooler height.
Production - CONSOLE and CONSWOLE: entry level 2-slot and 3-slot console cases! [Available Now!]
CONSOLE - 8.3L, 53mm CPU coolers, 2-slot GPU https://www.sliger.com/products/cases/cl520/ CASE Grained & Anodized Aluminum front panel Steel frame with Matte Black powder coat 343mm x 356mm x 68mm 8.3L GPU 2-slot GPU up to 145mm tall x 330mm long FANS 2x 120mm x 15mm fans behind GPU as...smallformfactor.net
Here's all our cases cooling options:
2-slot GPU
CONSOLE CL2 - 53mm air
SM550 - 55mm or 92mm AIO
SV540 - 75mm air or 120mm AIO
SM570 - 55mm air, 92mm AIO, 240mm AIO, or 2x 120mm AIOs
3-slot GPU
SM560 - 55mm air, 92mm AIO, or 120mm AIO
CONSOLE CL3 - 75mm air
SM580 - 55mm air, 240mm/280mm AIO or 2x 120mm AIO
SV590 - 55mm air, 360mm AIO, or 240mm + 120mm AIO
Question how would I set up my H100i Pro (Noctua Fans) and my 2 bottom fans.
My CPU is the 9700K (No OC) and the EVGA RTX 2080ti XC Gaming listed below
EVGA GeForce RTX 2080 Ti XC GAMING, 11G-P4-2382-KR, 11GB GDDR6, Dual HDB Fans & RGB LED - Newegg.com
Buy EVGA GeForce RTX 2080 Ti XC GAMING, 11G-P4-2382-KR, 11GB GDDR6, Dual HDB Fans & RGB LED with fast shipping and top-rated customer service. Once you know, you Newegg!www.newegg.com
Added info CPU Side panel with PSU will be windowed and the GPU side will be vented
You're planning on using the v2? The tubes coming straight out the block will make it so it won't fit inside the caseThanks!
Another Question the H100i V2 uses a Micro USB to USB header for the Motherboard is there any way to get a shorter cable. I am using the Z390 Phantom itx by asrock
1. you'll need the pigtail. The card width is 140mm which might even be pushing it for fitting in the case without an adapter for the power cables.Hi all (@KSliger),
Well I’ve in mind to go for SM550 to potentially replace my node 202.
I’m looking for better cooling overall & noise on demanding game.
I’ve several questions :
Thanks!
- Will my GTX 1070 gaming X fit with standard inlet or do I need to go for pigtail? How do you measure card height?
- I plan to put either is-vc45 (with 92x25mm fan) or heat sink of nh-l9x65 in semi passive mode (with dual 120mm at bottom, exhaust mode as it seems to be the most effective setup) what will be best cpu cooling? My cpu is around 65w.
- What is lead time if I order from density.sk?
Thanks for your answer.1. you'll need the pigtail. The card width is 140mm which might even be pushing it for fitting in the case without an adapter for the power cables.
2. The IS-VC45 will work better of those two but I encourage you to look at the Id Cooling IS-60, Cooltek LP53 or Cryorig C7G for better cooling
Interesting for is-60..![]()
I am using the IS-60 in my SM550 cooling a 3600x and it does a really good job, recommend swapping out the stock fan though. You also need some flat head screws because the included round head screws cause the side panel to bow.Thanks for your answer.
Thanks!I am using the IS-60 in my SM550 cooling a 3600x and it does a really good job, recommend swapping out the stock fan though. You also need some flat head screws because the included round head screws cause the side panel to bow.
