- May 8, 2015
- 806
- 2,959
SM580 does suppoirt 240mm radiators at top. It also supports some 280mm, and then any combination of two 120mm radiators.Does the SM580 Support a 240mm rad at top? The manual only shows support for 280?
TY in advance
TY in advance
Duracell jingle played in my head upon reading "copper top". Those jingles are effective.Decided to do a little mod to my SM560. "Copper" top! I think it came out great
More pics:
the website says you can use 240, yes.Does the SM580 Support a 240mm rad at top? The manual only shows support for 280?
TY in advance
@KSliger , just following up on this concern. Thanks.As for the debur mark issue, you're right because I didn't even notice it until I turned on my eagle eye. I would love a replacement but the problem is my original shipping address was my CA hotel when I was there last July. Now that I have the case with me in the Philippines, I'm not sure what are our options? Thanks.
I see it is density who apparently do not ship to the UKQuestion did anything ever come of a UK / European supplier for these cases (especially the SF580).
Please send an email to [email protected], can get a replacement sent.@KSliger , just following up on this concern. Thanks.
Not sure what the deal with Brexit disrupting shipments to UK is. Seems unnecessary and petty IMO.I see it is density who apparently do not ship to the UK
Guessing currently no UK supplier.....guess can blame this on darn Brexit too.
I see a comment on some restrictions on 280mm AIO sizes, what exactly is this restriction (have an EVGA 280mm AIO). Reading the x62 fits and think the evga is slightly narrower so guessing should be ok.
Also has anyone done much testing on the impact of the vented vs. acrylic on temps / noise for GPU?
Will not be able to get a 92mm x 25mm fan onto the Asetek 92mm AIO in the bottom of the SM550/SM560.@KSliger May I ask if a 25mm fan fits with the Asetek 645LT at the bottom of a SM550? Thanks a lot!
Thanks a lot! And, any "unofficial" way to install a 120mm AIO with a slim fan (43mm total) on the bottom of the SM550 and the SM560?Will not be able to get a 92mm x 25mm fan onto the Asetek 92mm AIO in the bottom of the SM550/SM560.
Yep, have the EVGA CLC in hand, and just waiting for the SM580 to ship. I'll let you know as soon as I do @rustyspoon .@Allhopeforhumanity is going to test a 280mm EVGA CLC AIO in his SM580. Might wait for what he sees. That is the only AIO I do not own.
Thanks!Not sure what the deal with Brexit disrupting shipments to UK is. Seems unnecessary and petty IMO.
If you are in UK please check out on our site, and we will retroactively (as in refunds/extra parts) try and get the best deal possible for you.
Not going to leave our UK homies hanging regardless of agreement or disagreement with what is happening.
Vented might be a bit better for min/max of your temperatures.
Legend.Yep, have the EVGA CLC in hand, and just waiting for the SM580 to ship. I'll let you know as soon as I do @rustyspoon .
I have absolutely no idea if it is possible. I know I can get a 120mm radiator into the bottom fan position but iut kinks the tubes. You could probably make something work if you drilled out the rivets to the center spine, and then installed nuts/screws in place of them? I honestly do not know and would not offically endorse anything.Thanks a lot! And, any "unofficial" way to install a 120mm AIO with a slim fan (43mm total) on the bottom of the SM550 and the SM560?
Maybe like this mod, with 2 Alphacool XT45-280 in a Jonsbo UMX3?These are both thoughts I had when working on it.
Might be better to do an updated version of Cerberus with the ability to swap out the rear panels to allow for standard mATX layout or for a 2x 280mm layout.
See this mod example in an X:
Of course. was just a thought.I have absolutely no idea if it is possible. I know I can get a 120mm radiator into the bottom fan position but iut kinks the tubes. You could probably make something work if you drilled out the rivets to the center spine, and then installed nuts/screws in place of them? I honestly do not know and would not offically endorse anything.
