Would the 400w brick be able to handle a 1080ti? I don't think it would fit next to to the card though. And even if it did the heat from the card would probably be an issue for the brick right?
I think you'd be cutting it close as the 1080ti Founder's Edition has a peak average consumption of around 250W and a momentary peak consumption of 300W. Obviously these numbers would be somewhat higher with an AIB card with a factory overclock.
With a peak of 300 I think it would be a perfect match for my i5 7500 65w CPU. Still unsure about it all fitting though.
The PCIE cables would interfere. The HDPLEX 400 will allow you to run higher wattage CPUs or do overclocking but it is not going to allow for a GPU that has cables on the side. If we ever see a GPU with the power connector on the end, maybe...but I doubt it.
I think it is realistic with a 65w CPU to see the HDPLEX powering a 1080ti, but it would be externally.
It would not. You would have to switch to the Gigabyte 1080 mini.And I'm not sure that unit would fit alongside my 1080 from zotac
If I had to get a new GPU it would definitely have to be a upgrade to the 1080ti but I'm happy with my 1080 for now and I'm in no rush to spend $500+ on a new power brick. And I'd also like to see what people have done (if possible) to quiet it downIt would not. You would have to switch to the Gigabyte 1080 mini.
You should be fine with a 2.5in hdd. It’s designed for both. May some combination of hardware out there won’t fit but it can’t a hurt to try.
Here is an early build in mine with a 2.5 in seagate sshdd and Sammy evo ssd.
If you're talking about the Dell 330W brick, then no. It's not built to handle the power spikes. Josh from NFC has done testing on multiple systems, and power options. He has a link to some basic results in the first post.Would the 400w brick be able to handle a 1080ti?
There is barely enough space for two drives, but I wouldn't recommend using 3M double sided tape to stick drives together. I've done it before and depending on how much you use, it can be damn near impossible to get them back apart... Trust me... lol. I would recommend using a tiny section of the quick-strip velcro pads, to stick two drives together. It's easier to get apart, and you can keep the velcro on them to mount in other cases or locations in the future. Once you're done with the mounting solution, you can just pull the quick release strip, and everything comes off cleanly.Do you know if there is any space left underneath the SSD/HD to fit another 2.5" HD with 3M tape?
Did that with S4M-C before, see my post here. The conclusion is you can, but 2mm between stacked hdd+ssd is too much. If that 3M tape is <1mm it should work.
Plus, Skyreach added 1mm to the height of the case so my mod would've worked in it.
I ended up dropping from three hard drives, to two, because I didn't want to have to deal with that and the extra cables and connectors in that area. I'd say, unless you really need the extra drives, just try to drop down to two.
"Which PSU to choose?
https://smallformfactor.net/forum/threads/skyreach-4-mini-s4m.5715/page-19#post-77858"
