Anyone test the Jonsbo HP400(37mm)?
Pretty good, but the fan can be loudy and buzzy.
More than temperature, on imgur pictures, we can see clock speed average between x38 or x39 (3800-3900mhz).
I believe it's from the Not From Concentrate channel, 40 coolers revieweddo you have link to youtube video?
@IntoxicatedPuma just want to check why is the Black Ridge with A12x15 fan listed at 68mm in the chart? It should only be 64mm at most (47mm heatsink + 15mm fan + 2mm fan clip). I'm using the setup in my X1 case (65mm clearance) and there's still 1-2mm gap left.
also today the Raijintek Pallas just popped up on my radar. not sure how accessible it is to you but really appreciate it if you could test and add it to the chart. keep up the great work!
@IntoxicatedPuma here comes the next project for you haha ID-Cooling IS-47K
by new Noctua you mean the L12 Ghost edition right? seems like a straightup re-badge/label of the old L12 (same heatsink, fin, maybe change from the B9 fan to the A9 fan) so a bit dissapointed.I can barely get through what I have and they gotta go do this! The new Noctua cooler should be coming out around the same time too.
For the Z490-I Gaming, it says two M.2 at top. I wonder how they find space to accommodate 2 M.2 SSDs? Could it, somehow, they are stacked? This could be an improvement as an M.2 on back usually just does not have much ventilation.
also per J-HACK there will be another version with 120mm slim RGB fan, even I don't like the multiple SKUs LOL
sure is because it is EOL haha. though would be interesting to test whether the A9 fan or the A12x15 would be better for it. hmmI had heard it would be similar to the old L12 but didn't know it was the same. Although that alone may not be too bad, it's been hard to find an L12 recently!
@billabong2606
Cooler + fan setup - fan speed at 100% & Delta temp
IS-60 (stock fan, blowing down) - 1520 rpm @ +60.7C delta
IS-60 (A12x15, blowing down) - 1717 rpm @ 59.5C delta
L12S (stock fan, below cooler blowing up) - 1839 rpm @ 52.3C delta
L12S (stock fan, below cooler blowing down) - 1785 rpm @ 54.3C delta
L12S (stock fan, above cooler blowing down) - 1781 rpm @ 53.3C delta
Generally speaking in the updated test, the L12S outperformed the IS60 by around 8C at all fan speeds. For the L12S, the temps do have some temp variation with different fan orientation, but it is very close to the margin of error. However, since I tested the different fan orientations in rapid succession, I would be pretty confident that the fan blowing upwards would be the most effective on the test bench. I would also agree that you are right, in such a case design it'd be better to have the fan blow upwards. I am planning to do an in depth test on the same case situation you are dealing with, but on the J-Hack Pure XL (similar design). It will be a few weeks before I get around to starting that though.
