cscssc
Which BIOS version did you come from to 3.70E? There are some versions that could 'cause a brick, e.g. stay away from 3.71!
As long as you don't have a way to boot UMAF with any BIOS above X300 1.90 (updated secure boot signatures on newer BIOS versions), I'd recommend to use X300 1.90C. I'm not sure atm if it's safe to flash X300 1.90C from 3.70E, I flashed from 3.60S. UMAF is required to change BIOS settings, because saving BIOS settings in the actual BIOS setup will cause a soft brick, where only removing the battery will help.
I'm not sure atm if X300 2.20 solves any issues with SoC/Uncore OC Mode and Curve Optimizer, haven't tried it yet.
My original BIOS version was P3.70B. I upgraded it to 3.70E using Instant Flash v2221 in the BIOS.
Currently, with version 3.70E, the system works fine when I install the original 3400G, and I’ve also reset the BIOS settings.
However, when I install the 5600GT, it still results in a black screen with no display, and the system keeps rebooting endlessly. I can only shut it down by removing the power.
Dr. Nick
71
57
Hm, AFAIR 3.70E should support the 5600GT. Could be a problem coming from 3.70B. 🤷🏻‍♂️
Dr. Nick
71
57
Unfortunately the problems of all BIOS versions above 1.90 remain with 2.30 was well. It's impossible in Advanced -> CTRL+Q menut to disable SoC/Uncore OC mode (is always enabled again, thus SoC voltage is always 1.15V and SoC frequency always maximum), and the Curve Optimizer settings are ignored for both CPU and GPU. Curve Optimizer for CPU works via the OC Tweaker Menu though.
I'll recommend to stay on 1.90 with A300s using the X300 BIOS, unless anyone finds a way to boot UMAF with updated Secure Boot signatures.
Reactions: hrh_ginsterbusch
20goto10
Hi, is this thread still being monitored? I have a query regarding using the 4650g and 3.60s.
Bios changes disappear when I pull AC power, so the cmos battery isn't saving the settings (the battery has been tested and it's fine).
Is there anyone out there who could point out what I'm missing please? I've read through the whole thread and I'm not sure if I've missed something obvious. Thank you!
Dr. Nick
71
57
Hm, that's weird. Before flashing my A300 with the X300 BIOS to use a 5600G, I've used 3.60S with a 4600G without any problems. I hope you haven't set the clear CMOS jumper, and forgot about it. ;) From what I've read, there shouldn't be any BIOS saving issues with 4650Gs either.
Reactions: 20goto10 and Phuncz
20goto10
Thanks for the advice! I've checked and the cmos has no jumper connected.
When I got this device, it came with 3.70 installed, running an officially supported CPU. I flashed to 3.60s and installed the 4650g. Could that have caused the issue? All I want to do is be able to save bios settings to enable secure boot for windows.
20goto10
I managed to resolve my issue. The previous owner had installed a new cmos battery, which I thought was old and needed replacing, so I replaced it like for like. They had installed a normal cmos battery when the a300 requires a reverse polarity battery to work properly.
