ToraSapphire
has anyone been able to flash an A300M-STX back to the A300 BIOS after crossflashing an X300M-STX BIOS? I'm not able to do so using the MSI utility I used before because I get a secure boot violation error, and changing any BIOS settings causes a soft brick where I have to unplug the CMOS battery to reset it. I have a 4700G in mine and went from A300 BIOS 3.60S to X300 BIOS 2.00.
I figured it out: I had to downgrade from X300M-STX P2.00 to P1.70 to disable Secure Boot, and then use the MSI utility to re-flash A300M-STX P3.60S. Took several hours of brainstorming to come up with that idea. It's super un-intuitive, but it worked for me.
HyphenK
Hello everyone.
My 5600g+A300 with 3.70E BIOS does not fully work - it could enter BIOS setting but was unable to enter Ubuntu.
I had to downgrade to 3400g and now it works fine with 3.70E.
I need some advice from anyone installed 3.70E.
HyphenK
So it doesnt save the settings anymore? CMOS battery gone kaputt?
cu, w0lf.
yeah I can't.
If I boot without CMOS clearing, the A300 cannot find any boot disc, so it keeps looping in the BIOS. The only way to resolve is CMOS clearing, and it boots normally just one time. Another reboot then stuck again. I can't understand why this thing is happening...
HyphenK
yeah I can't.
and it seems it is not a cmos battery problem, since i didnt have any problem before updating to p1.70 and 5600g, and i heard nothing about relationships between broken cmos battery and non-detected boot disc
hrh_ginsterbusch
1,089
459
Germany
wp-devil.com
if it doesn't save the settings / starw, then the boot disk disappears after reboot. and not being able to save the state, aside of some bios bug, could also point to a hw problem. hence CMOS battery as the easiest option.
HyphenK
maybe i need to re-flash p1.70 or flash p1.90 again... i'll try it later
HyphenK
so the second try... this time i used p1.90 and it didn't resolve the error, but i found that this is caused by not properly flashed bios. it kept fail to pass the validity check. maybe i need to try instant flash, or buy another ch341a or bios chip?
Dr. Nick
68
54
Did you try to re-flash P1.90 via "Instant Flash" in BIOS?
Figl
I can confirm that the firmware from x300 is the source of the problem with starting after saving the cmos settings. I tried flashing it back in 2023 with ch341 and xgecu t48. These are not just problems with starting. If you measure the voltage on the capacitors in the power circuits at this point, they will be very different from normal. This problem will persist even if you update the bios later via instant flash. I also found that if you do not enter the bios, there will be no problems. I think that the bios from x300 is configured to save data in cmos differently. Or there is an incompatibility of the knoll activator chip firmware
Robotica72
I know its been a while since this thread had activity, but Im hoping someone has an idea....
I have an a300 and Im upgrading the CPU to a 5700G. Ive tried a few BIOS' from the post, the only one I can get to POST is the 3.70E for the A300. As others have said, I can get it to POST but any changes in the BIOS causes it to go into a soft brick mode. So I need to clear the BIOS at that point to get it to post/boot again. Overall, its not a huge issue for me - but as I build the system out for my purpose, I may need to change a few settings.
Is there any known fix for this??
Robotica72
I rephrase that its not a big deal - it is - Every reboot requires interaction for the UEFI defaults warning... so that will be annoying on reboot / etc...
Dr. Nick
68
54
With 3.70E you should be able to use UMAF: https://github.com/DavidS95/Smokeless_UMAF
I'd recommend to flash 3.60S and official X300 P1.90 though, which still enables the usage of UMAF. Do NOT use 3.71A though!
Robotica72
Thanks! Ill give that combo a shot after my new NVME comes in - do the work in one shot. Hopefully the X300 BIOS will work this time, I have yet to have it boot off a X BIOS. I should have mentioned that Im using a CH341a programmer - Just more comfortable that way (Electrical Engineer).
bouncelinger
Hi there,
i am using a Ryzen 5600G in an A300 with BIOS 3.70E. The only problem i have is that the BIOS shows 4 instead of 6 cores. Is there a fix for this issue?
thanks in advance :-)
1,322
VIC, Australia
Hi there,
That's super strange, I haven't heard of that one before. I'm assuming you've already tried resetting CMOS to defaults?
cscssc
DeskMini A300 updated to P3.70E. I replaced the original 3400G with a 5600GT. It can’t boot — the screen stays black continuously. Even removing the CMOS battery doesn’t help. May I ask which version I should update to? Or should I use the other version, P2.10B? Thank you all for helping me solve this!
Dr. Nick
68
54
Which BIOS version did you come from to 3.70E? There are some versions that could 'cause a brick, e.g. stay away from 3.71!
As long as you don't have a way to boot UMAF with any BIOS above X300 1.90 (updated secure boot signatures on newer BIOS versions), I'd recommend to use X300 1.90C. I'm not sure atm if it's safe to flash X300 1.90C from 3.70E, I flashed from 3.60S. UMAF is required to change BIOS settings, because saving BIOS settings in the actual BIOS setup will cause a soft brick, where only removing the battery will help.
I'm not sure atm if X300 2.20 solves any issues with SoC/Uncore OC Mode and Curve Optimizer, haven't tried it yet.
