Changelog:change log of UEFI firmware 1.77 (X300) available?
Hello there,
as ASRock is releasing AGESA 1.2.0.7 for the X300 because of the AMD shutter issue, I wrote them if they will do the same for the A300.
This is their answer:
However they ask me to provide a proof. I put the 3400G in my ticket because it is supported by ASRock and Windows 11. But in fact I just have a 2400G, which is not compatible with Windows 11. So I can not provide the proof (besides that I don't even know if the issue also occur with this CPU).
Somebody has an idea? I think this is our best shot to get a new AGESA version.
Unfortunately for DeskMini A300 owners, I think ASRock doesn't want to update AMD AGESA anymore, because each time they implement a new version of AGESA it would take them a long time to remove the microcode parts CPUs allowing APUs newer than the "Picasso" generation (aka Ryzen 3xxxG) because if we look at the last BIOS finalized for DeskMini A300, it is the "P3.70" version and they have voluntarily left it in AGESA "v1.0.0.1", the only exception BIOS is the beta "P3.60K" which is under AGESA "v1.0.0.4 Patch B" but from which they removed the microcode CPU entries allowing the operation of the "Renoir" APUs (aka Ryzen 4xxxG), then there are the leaked Beta BIOS which authorized the use of "Renoir" APUs: versions P3.60L, P3.60N, P3.60O, P3.60R and P3.60S, who used an AGESA yet a little older than that of the bios P3.60K that is to say the AGESA "v1.0.0.2". I think ASRock intentionally leaves the A300s in old versions of AGESA so that the latter do not encroach on the sales of their DeskMini X300s.
Besides, on this subject, I would have a small consolation prize for those who would still use the DeskMini A300, which is no longer my case, I sold mine and switched to the X300, but I had the opportunity today to recover the latest leaked BIOS which is compatible "Renoir" aka Ryzen 4xxxG, many people think it is the "P3.60S" but in fact a latest version "P3.60U" which had been compiled just a day after the "P3.60S" bios, I had already tried to recover it when I still had my Deskmini A300 in my possession but unfortunately all the sharing links I had been able to find were all dead, but today by luck and chance I came across the post of a clever little Chinese who had reuploaded it via their "Baidu" upload system and via a "Baidu" link debrider I finally managed to recover the original ZIP file containing the leaked beta bios "P3.60U" and I reuploaded it on another free file upload service, c concerning the changes made compared to the leaked beta bios "P3.60S", I unfortunately have no precise information but I know that at the time when I was looking for this version, those who used it said that this beta bios corrected the problem of vSOC voltage being too low creating general instability when using a Ryzen 7 4700G or its PRO version the 4750G and DDR4 RAM kits with an operating frequency greater than 2666MHz, so with the beta bios" P3.60U" this problem is normally solved, but having no more DeskMini A300 at my disposal I cannot verify it, nor test this bios in general, here I told you everything I knew about this beta bios "P3.60U", I also sent a copy of this bios to the administrator of ASRock's unofficial Reddit who normally published it today in his "beta bios" section under "Deskmini" so if you want you can download it to his Reddit, but if not you You can also download it from this link:
https://uptobox.com/uuxyrfe2pquj
Sincerely,
HydrAxx
At the same time it's normal, it was me who sent him the same day I managed to get this famous Beta BIOS "P3.60U", so same source ;-)I'm surprised more people hasn't tried this BIOS 3.60U. I've since found another download location. They're the same file, really..... https://botflakes.de/asrockwiki/docs/bios/deskmini/
Same as "P3.70", ie old AGESA 1.0.0.1Edit: Can someone check the AGESA version for BIOS 3.70B?
That's a mega-bummer, that means the only real hope for A300-owners is a hacky BIOS modification over from the X300.Unfortunately for DeskMini A300 owners, I think ASRock doesn't want to update AMD AGESA anymore, because each time they implement a new version of AGESA it would take them a long time to remove the microcode parts CPUs allowing APUs newer than the "Picasso" generation (aka Ryzen 3xxxG) because if we look at the last BIOS finalized for DeskMini A300, it is the "P3.70" version and they have voluntarily left it in AGESA "v1.0.0.1", the only exception BIOS is the beta "P3.60K" which is under AGESA "v1.0.0.4 Patch B" but from which they removed the microcode CPU entries allowing the operation of the "Renoir" APUs (aka Ryzen 4xxxG), then there are the leaked Beta BIOS which authorized the use of "Renoir" APUs: versions P3.60L, P3.60N, P3.60O, P3.60R and P3.60S, who used an AGESA yet a little older than that of the bios P3.60K that is to say the AGESA "v1.0.0.2". I think ASRock intentionally leaves the A300s in old versions of AGESA so that the latter do not encroach on the sales of their DeskMini X300s.
Sincerely,
HydrAxx
Good luck to all of you, sincerely, if you manage to make them bend on this subject, well it would be a great victory for all DeskMini A300 owners.If we can literally get EVERYONE in this thread who owns an A300 to submit a ticket requesting the update for support for Newer APU's and Windows 11 usage it MIGHT help.
Might help....
Still, im going to try at least.
I used to have so many but business's wanted them replaced due to the use of the BETA bios for newer AGESA which resolved stuttering/crashing issues they had with ALL of the release BIOS's in the "official" release's.
Might help....
shop.slimq.life
That’s a very nice bit of kit, wonder how reliable it is. I’ve had a few USB-PD chargers just fail completely after about 6 months so you’d want to know it’s built to last!So, alternate chargers. Came across the fact that there's usb-pd to 5.5mm barrel adapter connector cables out there, so its possible to use a tiny USB-C GAN wall adaptor (like phone charger small) to power the Deskmini, however it tops out at 100 watts, so have to watch the power limit. That's the cheap and small solution.
There's also a pretty new 150w GAN brick with usb-pd and barrel output (20v 7.5a) out there, and its only slightly bigger than a phone wall charger. I haven't tried it but it looks promising.
150W DC+USB C GaN Charger
SlimQ 150W AC Adapter & USB C GaN Fast Charger PD 3.0 Multiport Charging Station Laptop Compatible with Lenovo 135W HP Omen Pavilion Dell XPS 15 Charger (no Good as 200W 230W Charger) About this item The AC adapter is mainly for laptops that require 120W/135W/150W power adapters. It is not a...shop.slimq.life
shop.slimq.life
What’s that? You’re going to try it out and report back? Good plan!They also make a 240w which looks promising for eGpu ect.
240W DC/USB C Charger
SlimQ 240W Gaming Laptop Adapter AC Port Power Adapter Type C Ports GaN Super Fast Charger Laptop Charging Travel Power Portable Compatible Dell HP MSI Razer Lenovo Asus Sony Acer Toshiba and More About this item Nice Style: The patented design of USB C 240W GaN charger offers a unique style and...shop.slimq.life
Kinda like the new HDplex, but external and with more utility due to USB-C pd.
Yeah but agreed total ? on the reliability
It looks like they are just potting it with epoxy.What’s that? You’re going to try it out and report back? Good plan!
::EDIT:: what are they filling it with in the gif? Mineral oil? Resin??
