Hello. Does the Sentry case fit into a laptop bag? If so, for which diagonal laptop should I look for a bag?
Thanks
Thanks
Thanks for answeringYou should check out the internal dimensions of the bag to fit the external dimensions of Sentry. Just the number of inches won't give you enough information because Sentry is significantly thicker than laptops.
There are quite a lot of bags that will fit Sentry, some may have slightly different dimensions but you will still be able to fit it because material will move around the case if you have leeway in one direction and you lack a bit of it in the other. The issue might be some reinforcing metal pieces that make it impossible to do so.
Essentially you should look for 17-18" laptop bags and check the internal size of the laptop compartment (important - sometimes internal size is not for just the laptop compartment, which is stupid, but still happens).
I need to replace the power switch on my V1.1. What size do I need again? 16mm?
So, did you guys got any answer from the reviewers? I would love to see the Sentry 2.0 being
Will there be changes made based on the reviews?
But look forward to see them pop up, are you able to share names a few of the youtubers who've received one?
Well... yeah. We're almost out of stockProbably within next few weeks first reviews will start to show up.
hmmm??![]()
Yes, of course there will be some changes, but we expect them in the field of user's manual (which currently we are changing every day for rev.2.0, because we have a delay in that matter), and in the quality control (the feedback which we will gather we will send to our submanufacturers to show them which elements should be improved).
Do you need another "outside eyes" english check on the manual?
Could you start posting those reviews here when they appear?
Those will be useful for us and will save us time for searching the web for them.
I am wondering, is anyone going to try the i9900k in any of their Sentry builds? I'm dying to try it with a Cryorig Cu copper cooler plus a Noctua fan. Will this melt my case? Definitely looking forward to the release of these bad boys either way.
