Prototype [Scratch Build]Project REAL CUBE (Back online, V3.0 soon)
4,796
Ah nice, I think I see the basics of the design.
Are you going to use a metal motherboard tray or will everything be wood?
4,796
It's just more difficult to get the cutouts and standoff holes correct is the issue. Most people just buy a tray or cut one off a case and build around it.
How will the video card be screwed to the case if it's all wood?
6,127
5,033
Belgium
Screws are so 1998, wood pins to secure a PCIe card is the way to go !
Go 100% eco-friendly ! #nomoremetal
Reactions: Minefoxi
4,796
Would you move the button to the back or something if you do the clean front?
It's less convenient without the front IO but I think it'd be neat with the clean front so it's not so obvious that it's a computer hiding in there.
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
LOSIAS
Jul 19, 2015
818
1,359
placement aside, with. front panel connectors are useful
Minefoxi
146
68
Germany
www.youtube.com
The GREAT UNVEILING VIDEO is here!
With more details and first renderings ;)
Rear view:
Top View with grill and ODD Slot:
General Theme:
Grills for outlet and PSU intake:
Reactions: jeshikat
6,127
5,033
Belgium
(Your pictures don't work)
Nice concept, I'm anxious to see what the result will be ! You seem to have a lot of space for CPU cooling, have you looked into which large coolers might fit ?
4,796
Looks great! So did you decide to go for the clean front then?
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
Germany
freilite.com
Exciting to see the renders! I like the idea of putting form over function somewhat and then see how you can fit everything inside. The case itself looks really good, I like wood as a material as well.
One piece of criticism, though: Your voice-over voice sounds extremely bored. It would highly improve the quality of your videos if you could try to sound a bit more exited, at least in my opinion.
Other than that, it's nice to have a video that explains your thoughts and maybe progress in the future instead of having to read a wall text.
QinX
541
374
The Netherlands
Just spotted this.
Of course it can't house the hardware you are aiming for.
But definitely a REAL CUBE at 12x12x12
EDIT:
Wow what is this magical forum? it automatically converted the kickstarter url to a that quick overview image.
4,796
I'm debating the Kickstarter integration because the card takes up much more space than just a plain link.
