It`s update for Sans MK1. Because it hasn't been improved for a long time, and it has been discontinued for some time.
As one of the earlier chassis that can support AIO water cooling equipment. Sans MK1 was very popular until competitive models of its kind were gradually born.
So I recently updated this model. Added more compatible support and better ventilation design.
prototype update
parameter:
3D size: height 235 x width 143 x length 335 mm
Internal volume: 10.3 L
Weight: 2 kg
Texture of material: steel / aluminum / rubber
2.5-inch equipment: SSD x 2
GPU specification: Max 330mm max. / 150mm incl. blank length / 3 slots(Amodel) / 2slots(B model)
Motherboard support: ITX
PSU specification: ATX/SFX/SFX-L
CPU radiator height: The total height is less than 60mm (A model) /The total height is less than 80mm (B model)
Specification of water cooling radiator: 240/280
Color: black / white
Update about the artistic style of the side panel:
I retained the classic tassel pattern of MK1 and added new mesh side panels and window side panels. And these three different materials are fixed based on the frame at the bottom. When changing the materials, you only need to change the corresponding materials you like
Structure demonstration:
CPU side structure
The exhaust gas of PSU is still downward alone, which does not affect the internal air flow. The position of PSU fixed support is padded up. So now 220V extension line can be built in, and there is no need to use special AC power wire as MK1.
The direction of the main board is now positive, and the extension cable extends from the bottom to the back. which can prevent some extension cables from hitting the bearing of the fan.
GPU side structure:
I put the coordinates of GPU down as far as possible. For some open cooling graphics cards, the heat at the edge can be quickly discharged out of the case.
And most of the video memory and inductive elements are distributed in the upper part of the graphics card, and the heat in the lower part is less. Therefore, the water-cooling absorption of the heat of the graphics card will be improved.
Bottom structure:
Many holes are opened so that heat can be discharged from the bottom.
Top structure and cooling fan support:
The compatibility of 14025 fans is added. At the same time, it can support 280aio water-cooled radiator. The hamburger structure with up to 3 fans is only 10L in volume.
Switching of back structure A and B mode:
By switching the screw position of the intermediate structure, you can directly switch between a (cpu80 / gpu40) and B (cpu60 / gpu60), and there is no need to plug in any element on the intermediate structure in the whole switching process.
PSU support:
no longer time...
HDD support
no longer time...
prototype update
parameter:
Weight: 2 kg
CPU side structure
GPU side structure:
Bottom structure:
PSU support:
no longer time...
HDD support
no longer time...
