Prototype 12.18L Dual 240AIO quite gaming PC case——Dual Cool MKII (4 months use report)
Tazpr
552
426
I can’t tell if SFX-L would be feasible or not. I’m going to guess no?
If you install SFX-L I think it will intrude on either rad or fan space, I'd suggest not using one.
I never went ahead with the purchase as I recieved no clarification from Warhead Team - a bit concerned this might be dead? :(
I mean, it's a new and updated design so I would say it's a legitimate item and don't be concerned about purchasing this.
skydoy
I Have also ordered one, The info i have on 31Agust the will end production, and will be ready to shi
@WH-team
If you have anything else you can share with us ? Some pics?
WH-team
102
186
@WH-team
now we finished panel build and next step is fabrication of internal structure. Because it is use CNC and we have wait factor`s order list finish then start another aluminum parts. So it may more 25 days
Khanele
Is the only way to get this from Taobao? Is there any option to EU?
skydoy
Some Great News
PDF for Instructions and color Info:
velka5simp
Hey, is there any update on the Mini MKVI? I really wanted to buy one once it's available. But the page says it is out of stock!
lasek
68
52
After reading this thread and the version 3 update notes, I am still confused about 2.5 slots GPU support, CPU air cooling dimensions supported, and the price / delays.
WH-team
102
186
The default version just install 2 slot card. and CPU side it`s 80mm more height. The 2.75 slot will match as an accessory. It will move the middle frame 20mm and reduce the CPU radiator height.
Firebear
35
Hi, I'm wondering are there already people with units received or can we see some build progress? Really curious about the case but I don't want to pre-order it yet until I can see some more pics with components installed into the newer, final version.
daemeh
Hey WH-team, I have some questions about the water blocks needed to be able to use this case - I saw in the pictures you posted on Chiphell that you're using a slim CPU block, and I can't find anything like that for sale. Also the GPU waterblock seems to have been customized, with the ports coming out of the side of the block, instead of perpendicular to it - like what we usually can buy from Barrow. Thanks.
