Hi community,
Problem:
All components turn on but no video output when using with riser.
Works fine without riser. (GPU plug direct into motherboard)
Riser works fine when used on a seperate build (Matt, gtx970, desktop psu)
Components assembled for my S4 mini build:
CPU: Ryzen 5 2600 (65w)
GPU: EVGA GTX 1060 SC (06G-P4-6163-KR)
MB: Asus ROG Strix B350-I
RAM: 2x4 GB Kingston value ram DDR4 2133
SSD: Samsung 970 evo nvme 500gb
CPU Cooler: Noctua NH-L9a
Power: HDPLEX 300w DC-DC PSU + DA330PM111
PCIE Riser: NFC Systems 16x PCIE Ribbon Cable
#bios, I do have this upgraded so that it can utilise the ryzen cpu. But there isn’t any option within it to allow me to change the pcie mode.
My current hypothesis is that the riser doesn’t seem to work for this specific combo (any recommendations of what riser to get?).
Another hypothesis is that I should downgrade my GPU to a 1050ti (any recommendations?).
Thanks!
Problem:
Thanks!
