Completed S401: Salvo Studios <8L mITX Steel Unibody Chassis w/ GPU & CPU fans in same direction
vanbeveren
142
95
I have the video card on the bottom with no stability issues. Mainly, it's for aesthetics - I haven't considered it from a functional point of view. Blower card, so heat gets sent out the back + I like having the 60mm fans by the CPU cooler exhaust up. Stability hasn't been an issue with the included feet. Might be something interesting to try someday; I'll let you know if I do.
Interesting… I will not have a blower card, at least not at this time, so it is making me think I should do the opposite.
I guess it’s not too difficult to test both ways
Are you using the 60mm fans from the website or from a third-party?
If it’s third-party which ones?
Reactions: grsychckn
annasoh323
424
314
I have a set from Salvo (the Delta clones) but I also have a set of Gelid Silent 6 fans too. I must confess that I've been too lazy to swap for the Delta clones (sorry @grsychckn) so I can't speak to performance. I do believe they are making a difference. Temps compared to the RVZ02 are much better and I can anecdotally detect that it's extracting a fair amount of hot air. I haven't done any science with respect to figuring out ideal fan curves (associate fan speed with a certain pressure drop blahblahblah lots of difficult math I don't know how to do). I just sort of winged it but my CPU seems to like it, so I just leave it. Did just hear a saying that I'm going to hang onto though: "If it ain't broke, fix it till it is." (thanks to whoever I saw it from).
Sparkles
43
65
I'll agree with @annasoh323 in that it's mainly for aesthetics for myself having the CPU on top and GPU on bottom. I'm pretty sure it's the weight of a reference 2080 Ti helping this, but it's extremely bottom heavy and very stable when standing up.
In terms of fans, I'm using "Evercool EC6015SH12BP 60mm x 15mm Hi-Speed Dual Ball Bearing PWM 4 Pin Fans" on the top capped at a very low RPM (~2300) to stay silent.
grsychckn
Salvo Studios
Oct 11, 2017
1,093
1,845
I have used the Gelid Silent 6 fans, Delta PWM, and my 'cloned' Delta fans. The Gelid fans don't move much air and seem to me to be average in terms of noise. The Delta and clone fans are on par with the Gelid fans when at idle. The Delta fans can spin at higher RPM than the clone fans so they also can move more air at the top of the RPMs, but they are ear-splittingly loud. The clone fans get extremely loud as well and what I've found is that performing the fan tuning in your BIOS and then setting them to quiet/slient is usually a good mix. I'll also say that I had the idea to cut out a shroud for the 60mm fans such that they are forced to extract air directly from the CPU cooler (C7 Cu) and that made about a 3-4 degree difference on this i9-9900k I've been building. I took card stock from a Noctua box and made the shroud, then I cut it out of a piece of aluminum and I'm going to clean it up, put some edge guards on it, and powder coat it for this customer's build. It's a nice touch, but the card stock was just as good as the aluminum in the end - so maybe try that and spray paint it instead of cutting it from aluminum.
Cardant
Damn I really like the S401, sucks that I'd have to pay more than half the price of the case when it's not on sale just to get it shipped to Europe ...
raudy5
I’m having an issue getting the RTX 2070 to line up properly with the slots attached to the case...I’m short a few mm and out of ideas. This is a prelim assembly before paint etc, so I need to make sure this is feasible. Just an FYI before you ask, the faceplate is 100% flush with the case when the misalignment photo was taken...so much so I couldn’t fit a fingernail in, so I am 100% certain the problem is not that it is not flush. Also, removing the faceplate from the card is not an option as it does not come off.
Picture here
grsychckn
Salvo Studios
Oct 11, 2017
1,093
1,845
Picture here
I've had one other report of this problem before. In my last batch of cases I sold, I tested each one with a card just to be sure everything lined up. Unfortunately, I don't believe I have done this with the last few of the cases I packed (just an oversight). There are a few options I can offer:
1. loosen the two screws that attach the riser to the chassis and see if you have any wiggle room.
2. If that is still a problem, I will take a spare PCIe extension cable I have and modify it to give you the ability to slide it just a little bit to make things fit right.
If we need to opt for #2, contact me via e-mail (salvostudiosltd@gmail.com) with your address and I'll get to work on shipping you that modified cable. I'll also need a picture of your existing PCIe cable as I've recently decided to swap to a different style and would like to replace yours with the same type so you don't install it incorrectly.
grsychckn
Salvo Studios
Oct 11, 2017
1,093
1,845
I wish I was as big as Amazon too and could afford to push around the shipping companies to make them discount their prices. As it stands, I get a 66% international discount with UPS and the prices you see on my website are as near the actual prices I pay UPS. I've not been able to ship anything internationally (over the Atlantic/Pacific) for less than $90US - and that's what I'm charged. USPS is sometimes significantly cheaper but their floor price has been a pretty consistent $75. Shipping sucks.
grsychckn
Salvo Studios
Oct 11, 2017
1,093
1,845
Check this out: Custom loop in an S401.
I got an e-mail from a customer with these incredible pictures last night. I got his permission to post them here. He had to make some modifications, but according to him things worked out well. So much that he just bought a second S401.
Piewalker
47
76
OBJECTIVE
Water cool a high performance CPU and high performance GPU in the S401.
TLDR
I was able to fit the pump and XSPC 240mm Crossflow radiator in the S401 to water cool both CPU (R7 2700X) and GPU (RTX 2080 Ti) with acceptable thermals without heavy modifications (e.g., cutting out the backside of the chassis).
See the complete photo set here (a few more photos than what Greasy posted above).
System Specs
Cooling Solutions
Alphacool DC-LT 2600 Ultra low noise ceramic - 12V DC
Alphacool DC-LT Plexi top
Alphacool DC-LT Individual Reservoir (13140) (temporary solution to bleed system)
EKWB EK-Velocity CPU Waterblock, RGB, AMD CPU, Nickel/Plexi
Alphacool Eisblock GPX-N Plexi Light Nvidia Geforce RTX 2080Ti M01 (11664)
XSPC TX240 Ultra Thin Radiator (120mm x 2) 20.5mm thickness + 22 FPI
ATP Surethane Polyurethane Plastic Tubing, Clear, 1/4" ID x 3/8" OD, 100 feet Length
8 KOOLANCE Rotary Elbow Compression Fitting for 06mm x 10mm (1/4in x 3/8in), G 1/4 BSPP
1 KOOLANCE Fitting Single, Swiveling Elbow, G 1/4 BSPP (used for the second right-angle down turn to Crossflow in-port)
1 XSPC G1/4" 10mm Male to Female Fitting V2, Chrome (spacer prior to the right-angle down turn to Crossflow in-port)
Distilled water + PT NUKE PHN Concentrated Biocide
METHODS, RESULTS, AND LESSONS LEARNED
A single custom loop to water cool both the Ryzen 7 2700X and the RTX 2080 Ti (overclocked) is feasible in the S401 with a single 240 radiator to achieve acceptable temperatures during high-end gaming and to obviate any major modifications (such as cutting out the backside of the chassis to allow airflow from both sides of the GPU).
Just a 240 rad. That’s it. I was skeptical, too. I would’ve liked to put in a 280, but I've feared that to do so successfully may require cutting out the back of the chassis where the GPU sits (although I may be able to fit a 280 without modding – a hypothesis to be tested). At the moment I don't know of any 280 Crossflow radiators that could fit (needs to be less than 315mm in length, though a dual-pass 280 may work – there are a few 280 dual pass rads that are 312mm in length). But thus far, the XSPC 240 Crossflow has worked beautifully to control temps and allowed an efficient routing of the custom loop’s 1/4-inch flex tubing. While I was worried a 240 rad would not be enough at first, I found that judiciously selecting the appropriate fans can make a BIG difference. The fan solution I settled on works to cool the entire system with just a single 240 with this setup.
Fans Matter
For fans, I went through two sets of fans before I settled on the EK Furious Vardar 3000 RPM fans. They have some of the best CFM and static pressure I’ve seen. At first I didn’t think I’d be able to fit standard 25mm thick fans, but I was able to make the GPU + waterblock lay nearly flat on its backplate and it all fits (barely). Before I used the EK Furious, I tried EK’s Predator 2200 RPM fans (F4120ER) and got temps in the mid- to high-70s under load. I’m glad I moved to the Furious because they have superior CFM compared to the other EK fans:
CFM
EK Furious EVO (3300 RPM): 107 CFM = 181 m³/h
EK Predator F4120ER (2200 RPM): 77 CFM = 131 m³/h
Static Pressure
EK Furious EVO (3300 RPM): 5.81mm H2O = 57 Pa
EK Predator F4120ER (2200 RPM): 3.16mm H2O = 31 Pa​
And even before I used the EK fans, I actually first started with two 15mm thin Silverstone slim 120s, which were very quiet at 2200 RPM max duty. However, the static pressure was suboptimal – meaning that although temps were controlled, it took forever to cool down after load, even at 2200 RPM. The case was physically hot to touch.
Initial Custom Loop Setup (Failed)
And before all of this, I actually set up a completely different custom loop that, ultimately, just didn’t work as well as I wanted with the small radiators. I got unsatisfactory temps with 2 small Alphacool radiators – the Alphacool Triple 50 (located at the front bottom of case just below PSU with only two 60mm fans mounted internally) and an Alphacool Triple 40 w/Noctua 40mm PWM fans floating in the space between PSU and motherboard. It just wasn’t enough radiator surface area to control thermals, which rose to 89C under load. Plus, the 60mm fans were miserably loud and untenable even though idle temps were in the 30s C. If I was going to go the tiny radiator route, I would’ve needed to squeeze in one more small one to achieve sufficient cooling to run fans at a slower speed and thus keep fan decibels acceptably low. I would’ve tried to add an Alphacool double 40 or a Magicool double 40 slim, but on the face of it I couldn’t see a way to do that comfortably with everything else in there without a drastic case modification.
Airflow Considerations
Ideally, you’d want the radiator and its fans unobstructed on both sides. Here, the GPU water block is directly underneath it. Although I was skeptical, I found the EK Furious Vardar 3000 RPM fans really do have the power to force air through the Crossflow and out the small spaces between the GPU water block and rad regardless of the GPU water block being a wall that somewhat obstructs the egress of hot air. The exit air flow pattern probably hits that wall and then looks for any crack out, so its path is probably very chaotic. However, there seems to be more than enough positive pressure with these fans to force out the hot air and cool the system effectively. Yes, a 240 rad can cool a 2080 Ti AND a R7 2700X. Oh, and I overclocked the 2080 Ti to 1995 mHz; I kept the 2700X at its stock frequency of 3.7 mHz). To aid with internal cooling, I just added three additional 50mm Delta PWM fans (not pictured). One sits directly over the motherboard VRMs (under the return flow tube), and the other two to the left and right of the GPU waterblock inflow and outflow. I believe this helps under load.
Custom Loop Pump and Flow
Once again, the Alphacool DC-LT performs admirably for this SFF build. I’ve only done one other SFF build, an S4MINI, and I used this small pump exactly how I did here, too, floating above the North side of the CPU socket. It rests perfectly between the two Northern-most CPU compression screws and slides up under the lip of the top end of the case. If I used the CPU Velocity block in the MINI, however, the plexi block wouldn’t fit. In that MINI build I actually used a smaller profile CPU water block that I LOVE (the Liquid.cool Strike ONE CPU Waterblock - AMD AM4, which is an even lower profile block compared to anything else I’ve seen and achieves the same results). To fit the block under the lid, I used a low profile G1/4” plug by EK to seal the block.
Before closing the loop, I actually used a reservoir first to bleed the loop and then carefully removed it from the pump block via its 4 long screws. Alphacool builds this small DC-LT reservoir that mates with the pump block/plexi top in a similar way to how some larger D5 pumps are configured with their reservoirs. The reservoir is very useful to add water and bleed the loop. There’s greater chance of spillage if only the plexi top is used. When the reservoir is unmated, the plexi top can operate on its own as a closed housing for the pump and the top plug allows easy access to the liquid to either adjust the water volume or add biocide as needed. There are some pockets of air in the loop, but it's fine.
CAVEATS and MINOR MODS
Aesthetics
I would’ve liked to sit the RTX 2080 Ti to the open side of the case, in other words, on top of the fans and radiator so we could see its clear plexi window and RGB (the water block is the Alphacool 2080Ti M01 [the M02 is sold out right now]), however the rad fans would be starved for air that way. To remedy that I’d need to cut out the back of the chassis in that spot. I may still do that if I upgrade to a slim 280mm radiator with 2 x 140mm fans. However, the drawback to that approach is the graphics card I/O is left with only one Display port that extrudes so much width-wise that it wouldn’t fit inside the case with the lid on if the radiators and fans were underneath it. Ultimately, I think I arrived at the best decision with these trade offs since I had to do very little modding to make the 240 Crossflow fit. Plus, using a Crossflow radiator instead of a dual-pass radiator allowed me to use more direct tubing connections. It’s just more straightforward and cooling is just as efficient (if not slightly more) than a dual pass rad. There's a good Jayztwocents video on Crossflow vs Dual Pass radiators where he tests both and discusses the pros and cons. He also has a good video from a couple years ago that I believe still applies today -- it's titled "Was a 240 Radiator enough?? Temp testing the ITX build." Jay concluded that a 240 radiator was "more than enough" for both CPU and GPU. And with this S401 build, I've arrived at the very same conclusion even though I'm using a slimmer rad than what he recommends (he recommended 30mm rads).
GPU I/O
Since the GPU + Water Block sits virtually flush on the back side of the case, most of the GPU's display ports/HDMI/Type-C are covered up since they don't line up with the pre-cut GPU slots. The entire bottom row is covered. Only the single top level display port is available. This could easily be fixed by cutting out that portion of the case. Maybe in the future.
Below are the small mods I made to make the graphics card lay nearly flat and ensure the 240mm radiator would fit.
Minor Modifications
  • Removed metal block. I sanded down the middle rectangular block welded to the chassis just South of the motherboard – there's a row of them. This metal piece was interfering with laying the GPU nearly completely flat. The other blocks didn’t need to be touched (what are those blocks for anyway? Greasy informed me that they're for zip ties. Cool. Well one less zip tie-down).
  • Removed the front USB 3.1/Type C connector. I also had to remove one the posts it sat on so the Crossflow radiator could sit as far down as possible in the bottom of the case.
  • Modded GPU Bracket I/O area to allow the GPU bracket to reach farther back. If I didn't do this, the GPU wouldn't lay down as far as it could.
  • Power Button Resoldering. I had to resolder one of the power button cables – I ripped it off messing around with different PSU configurations. As an aside, I found flipping the PSU vertically would have actually worked, and that flipping/reversing the PSU the other direction with the fan facing to the rear of the case would have also worked. I would’ve done just that to move the PSU right behind the power connector to free up space below the PSU to install the Triple 50 radiator. However, I’d have to cut out the back of the case to give the PSU air when it needed it (it doesn't spin all the time since it's Titanium-rated but I didn't want to take that chance of starving the PSU of air since it's fueling the power-hungry RTX 2080 Ti and would most certainly need to spin up under load). I avoided modding the case by going with the conventional PSU configuration.
  • Shaved Power Cable. By shaving the top of the power cable, which makes contact with the top of the case, I was able to move the PSU closer to the top of the case. I gained about 5mm of extra space between the PSU and the GPU/Radiator/Fan complex by doing this. It made it easier to plug in the dual 8-pin PCI-E power cables. I shaved it with a Dremel barrel sander, which takes the plastic/rubber right off. I was concerned that I'd contact wires, but nope, there's TONS of plastic/rubber shielding on those things.
  • Quarter-inch Flex Tubing. I routed the flex tubes in such a way that I can literally lift all the components out without disconnecting anything (radiator, GPU, and the Alphacool DC-LT pump). That gave me the flexibility to reconfigure and re-seat stuff AFTER I filled the loop with distilled water/PHN Nuke. Of course, I'm very cognizant that if this is done too much it puts stress on certain fittings and so I always keep an eye out for leaks. The only leak I've had was on the CPU-out fitting during initial filling. The fitting wasn't on tight enough (I apply fittings "tight-but-not-too-tight" at G1/4" base connections but I try to go "pretty tight" on the tube-side of compression fittings).
  • PCI-E Riser. I had to use the 180-degree connector in lieu of the 90-degree riser block to make the GPU lay as flat as possible. It's 20cm in length, I believe. EDZY brand.
  • Backplate Screw Replacement. I replaced the screws on the EVGA backplate (which I knew was a fantastic backplate per Jayztwocents, so I kept it, opting not to buy a third-party backplate) with low profile M3 screws. The original M3 screws on the backplate have a cylindrical head that is 2mm that pokes out way too far from the plate – they're not countersunk (that may have been a benefit of a third party backplate). Although I didn’t use countersunk screws to replace them, I used a very low profile hex top that’s <1mm and rounded. So I gained an extra 1mm of space simply by selecting different screws for the backplate. Every millimeter counts!
  • Thinner Thermal Pads on GPU Water Block. I ended up having to discard the thicker Alphacool thermal pads because the water block wasn't making contact with the GPU. I had to get a flashlight to see in-between the card and the block to see if it was contacting the GPU and I could clearly see the gap. I actually gasped in that moment like Doc Brown from Back to the Future. I tore it down again and cut my own aftermarket thermal pads that were very thin (1mm I believe). They're the blue ones that are everywhere on Amazon.
CONCLUSION
It works. Huge thanks to @grsychckn for creating a highly-portable SFF case that is capable of not only harnessing the power of a fully-powered desktop gaming computer, but one that can be completely water-cooled, as well.
annasoh323
424
314
I just went through a lifetime of emotions looking at this. I can't believe my eyes. If you ever do put a "Featured Builds" page on your website, make sure this one is near the top. This is amazing.
And he even used the stock PSU cables! I just can't believe this is real. What was in this morning's coffee exactly oh my goodness...
Reactions: Piewalker
2,719
2,854
That is very cool but it looks like the radiator has to be sitting on top of the GPU, wonder what kind of airflow he is getting.
annasoh323
424
314
True. I always wonder that with rad placements like this. Ideally, there's enough of a gap to get some air through. Unfortunately, if grsy posted the pics himself, then the builder probably isn't a forum member. Would love to see the spec list, build process, and performance figures.
grsychckn
Salvo Studios
Oct 11, 2017
1,093
1,845
He's joined the forum and currently waiting on his first post to be approved by @confusis .
Piewalker
47
76
Thanks for these comments, guys. I hope I answered your questions in my post above (finally approved since it's my first post). A more complete photo set here and benchmarks are forthcoming. So ... which benchmarks should I run to illustrate temps? I already ran Cinebench and Unigine Heaven and temps didn't get past 60C. I need a benchmark that shows temp output as a screenshot I can show you guys. Ideally something that stresses both CPU and GPU. Recommendations?
FYI, I was just playing Battlefield V and my max CPU temp was 67 and max GPU temp was around the same. But after playing a game, it appears the GPU tends to cool quicker than the CPU and is 4C to 5C below the CPU temp. Playing Anthem, I get into the low 70s. Ultra game settings on both. Apex Legends is low 60s. I haven't tried Shadow of the Tomb Raider or Metro Exodus yet.
Happy to answer any and all questions.
annasoh323
424
314
Man, I don't even know where to begin. I'm not a real benchmarking expert but could you run something like ROG RealBench? I thought that had an option for an all-system stress test. If not, then maybe run a couple of stress tests simultaneously, maybe Heaven and something CPU-related like Aida64. Gaming results look really good. What resolution/settings were you at and about how long were you playing for?
Really admirable work. Builds like this shouldn't exist, yet here you are. I think that's why I love SFF - folks like you pushing boundaries like this and making something new.
Piewalker
47
76
I added three 50mm PWM Delta fans and an addressable RGB strip. Just wanted to share the current set up since I'll be adding benchmarks later and I didn't want people to think there was no additional active internal cooling. After installing them and playing games, it looks like these fans may reduce temps between 2C and 4C. Overall, the CPU runs hotter than the GPU, but I think the direct air on the motherboard VRMs from this one 50mm fan does indeed have an impact on CPU temperature.
Piewalker
47
76
Just got this Black Ice Nemesis 280 rad and I'm just resting it on top of the current set up to gauge if it will fit. It appears it will fit length-wise, but it's unknown if it'll fit width-wise since it's 30mm thick. The current 240 rad is 20.5mm thin (XSPC Ultra Thin 240) and I was able to fit 25mm thick EK Furious fans. To make this 280 fit, I'll need to use two thin 140mm fans. When I attempt this 280, I think I'll first try the Cryorig XT140 1600 RPM fans since they're only 13mm thin. *EDIT* - The Cryorig fans have a 120mm mounting pattern and won't fit this rad! Does anyone know of slim 140mm fans for this radiator?
Below: View of the "right" side of the case. The rad's inflow and outflow tubes can probably be overlapped some and run parallel to each other. The 1/4 ID 3/8 OD flex tubing is small enough to find a path up the side of the case then make a left turn before the CPU to route back to the GPU and pump.
Below: View of the "left" side showing the 280 will likely fit in this case, but it'll certainly be a tighter fit than the 240.
I'm fairly confident this 280 will fit, albeit with the tradeoff of less fan power with thinner fans that likely have much less CFM and less static pressure. This rad would definitely not fit without thin 140s. However, with this rad being thicker and obviously slightly larger than the 240, it has sufficient extra radiator surface area that will likely offer greater cooling potential and provide thermal overhead. At this point, I'll probably hold off using this 280 until my next S401 although I'm quite curious about this rad fitting right now.
Piewalker
47
76
Thank you! Quick response on my display. It’s a 32-inch Pixio 165hz (144hz Freesync) monitor and, of course, G-Sync works on Freesync displays now. More later. I may not be able to get to benchmarks until the weekend.
Reactions: annasoh323
