Collecting parts but will be moving from my L2 (EDIT: i7 3770K & 2x8GB G Skills on P8Z77-I Deluxe, 2x840 Pro SSDs, Galaxy 750 Ti LP) to an S4 after coming back from holidays. Bought a 32" HP Envy monitor and the S4 will fit nicely I think underneath. The mix of connectors on this monitor is 2xHDMI and 1x DisplayPort so got a short 1ft DP cable and a stainless vandal switch in, should look good on black. Resting place behind keyboard should clean up desktop and wiring, L2 was too thick for that space.
Got in the ITX30 heatsink from Korea off ebay, damn this thing is small. Probably mount it in the L2 first to get a bit of a comparison to my AXP-100. Also dug out long bracket for my Galaxy 750 Ti LP card will mount Dell brick 7.4mm connector in VGA spot on bracket for the time being.
Looking at upgrading GPU card as it does not have a DP connector and other 2 sources I use (OTA Tuner, and work laptop only have HDMI) though may get adapter as I wait for GPU refreshes. Still have a 250W HD-Plex if I get something like a GTX960, though the wiring could use some shortening and sleeving or something.
