Thanks. Any idea on length?They are 6-32 screws. You just gotta find ones you like
You may want to rotate the heatsink so it doesn't exhaust directly on the first memory module. Josh has seen significant deterioration and failure of memory with that.
Everyone still abides by the laws of thermodynamics...Kryonaut is not a liquid metal TIM. Thermal Grizzly's liquid metal is Conductonaut and their Kryonaut is just a standard silicone-based thermal paste.
I did notTidied the wiring on my build
Bifurication in an S4-Mini? Did I miss something or is this new?I did not
just swapped the Noctua fan with a bit larger Scythe hoping to move some air around the VRM, too. no temperature tests yet.
The backplate on my 1080 Ti Mini literally does nothing and I'm guessing the 1080 Mini is the same way. There's no thermal pads to transfer heat and it is covered in a protective plastic film that actually insulates heat. I removed mine to fit a scythe fan behind it. This requires removing the heatsink first, so keep that in mind.
Awesome. You know the correct length? All my S4 hardware got scrambled.
I fixed 80% of my coil whine with some epoxy on my HDPLEX300 coils, check my build log in my sig and check the last post. actually its this: Post #64However I have a couple questions for the seasoned S4 guys. This will be my 3rd S4 build that I am planning and I hated the HDPlex 300 with a passion due to the coil whine. My question is has the coil whine been improved or gone away all together with the new 400w under load? I love this case but I have never found a setup that has worked as my main PC well with noise. The case design is second to none and I love it and haven't found a better looking case in my opinion yet.
quite commonBifurication in an S4-Mini? Did I miss something or is this new?
I fixed 80% of my coil whine with some epoxy on my HDPLEX300 coils, check my build log in my sig and check the last post. actually its this: Post #64![]()
had the hd plex 300w and it only coil whined when i was at max really. I have the 400w one and i never notice any coil whine. But again i down graded from a gtx 1080 to a gtx 1060 and i am much happier with the noise and works for what i need it for.However I have a couple questions for the seasoned S4 guys. This will be my 3rd S4 build that I am planning and I hated the HDPlex 300 with a passion due to the coil whine. My question is has the coil whine been improved or gone away all together with the new 400w under load? I love this case but I have never found a setup that has worked as my main PC well with noise. The case design is second to none and I love it and haven't found a better looking case in my opinion yet.
I have a 1060 ready for this build. The only concern I have is noise and performance on my 1440p ultrawide.had the hd plex 300w and it only coil whined when i was at max really. I have the 400w one and i never notice any coil whine. But again i down graded from a gtx 1080 to a gtx 1060 and i am much happier with the noise and works for what i need it for.
yeah a gtx 1080 barely drove my acer x34. I have doubts for a GTX 1060. But fingers crossed for youI have a 1060 ready for this build. The only concern I have is noise and performance on my 1440p ultrawide.
I'd say 1080 minimum for 1440*3440. even with a 1080 i would sometimes struggle to max games and stay above 60 fps. i actually just upgraded to a 1080ti for my ultrawide set up and id say that its the perfect GPU got this resolutionI have a 1060 ready for this build. The only concern I have is noise and performance on my 1440p ultrawide.
I have had a 1080 and with the games I play it doesn’t really matter. If I want ultra then yeah a 1080 is the best but I don’t have the budget or the noise tolerance for a 1080 Mini right now. I don’t really care about max settings all I’m aiming for is medium at 60 FPS and I don’t think I’ll have an issue with that.I'd say 1080 minimum for 1440*3440. even with a 1080 i would sometimes struggle to max games and stay above 60 fps. i actually just upgraded to a 1080ti for my ultrawide set up and id say that its the perfect GPU got this resolution
I'm curious about the durability of the powdercoat myself. It should be perfectly fine but I'm terrified of chips and having to pay a large fee to refinish it.I'm thinking about getting the aluminum powder coated soon but I'm not sure. I want a finish that is very durable as this will go in and out of bags very frequently
My dad suggested bed liner lmaoI'm curious about the durability of the powdercoat myself. It should be perfectly fine but I'm terrified of chips and having to pay a large fee to refinish it.
