IT'S OVER 9000!!!
Here is a picture of it next to the Eurocom:
IT'S OVER 9000!!!
How do you like the Eurocom? Went ahead and bit the bullet on one so I guess I'm stuck with it either way ha. Will be getting it mailed out to you next week for the connector end swap
Speaking of, can you post pics of the connector your using for the input to the mini and the other end of Eurocom's DC cable?
I tried using the search function to find what I needed, guess I fail. Anyone know what the best cable length is for 2 sata cables for SSDs on the rack with the z270i motherboard? Forgot to pick up a couple of shorties lol.
I think for the z270i mobo it's like
10in for cpu power
3in for mobo power
and 13in for gpu
so estimated 10-12in for sata SSD
feel free to correct me cause I'm probably wrong haha
So, in a vertical orientation, do people tend to prefer the button to be at the bottom or the top?![]()
Fair pointsI like having it with the button at the top, it seems to be more stable that way. I think it looks better with the button on top. Also this orientation puts the power cord at the bottom/rear instead of the top/rear which i prefer.
IT'S OVER 9000!!!
Has anyone built a system using the Quadro P2000 in the mini?
make sure you update the BIOS on the z270i. It has had issues with cold boots if your CPU or RAM are overclocked and have a voltage bump. My RAM is stuck on its 4000 MHz XMP and my 7700k is overclocked to 4.5GHz and undervolted to 1.8v and its cold booting just fine. When ever i go above 4.7 on my CPU i start to have cold boot issues.... its a well documented issue with our board, sadly.Any of you guys have problems with the HDPLEX 400w, Dell 330w brick and the Asus z270i not wanting to power on when the power has been cut either at the outlet or otherwise? I've narrowed to issue down to being XMP related i think, but tweaking the SA voltage has not helped so far.
I can always get the system to boot flawlessly by holding the power button on the S4 and restarting the system, and the system in itself is also rock solid. Just wondering if it has anything to do with the power solution i am using?
Woohoo, mine just arrived, #486. I'm now a card carrying member of the S4 club haha.
make sure you update the BIOS on the z270i. It has had issues with cold boots if your CPU or RAM are overclocked and have a voltage bump. My RAM is stuck on its 4000 MHz XMP and my 7700k is overclocked to 4.5GHz and undervolted to 1.8v and its cold booting just fine. When ever i go above 4.7 on my CPU i start to have cold boot issues.... its a well documented issue with our board, sadly.![]()
DANG! That sucks bro... welp. Drop your OC? try that?I am running the very latest BIOS unforunately
Got mine yesterday as well! #493. Looking to take this silver casing in for some powder-coating. Would anyone that has had it done before suggest going locally near myself or looking online and shipping it to a painter?
IT'S OVER 9000!!!
