Did you happen to get a tracking notification email or did it just arrive? I ordered a day before you.
EVERYONE gets a tracking number.
...Unless I mess up.
I would assume the same time every else gets their bezel. Since they are all hand made it is cheapest for josh to order in bulk and do them all at once is my guess. But you never know. I believe the site said 1-2 weeks after the normal ones are shipping for the bezeled cases.I already have an s4 mini since february mate. Im only in queue for a bezel and a long switch, which is why Im just a bit curious about when these might be in circulation. Not in a hurry (maybe), just hungry for news![]()
Your using a single noctua? Try to do a furmark and compare your temps to mine I wonder if it cools better.Just got mine in today, #440. The build quality is just impressive Josh, seeing it online really doesn't do it justice. Took me about 2 hours to complete my build, was able to cram my GTX 1080 similarly to Docs rare breed build. This took me by surprise how quickly.i got it, so I still have cables on the way from @royalba94
Can't wait to update the build log and show some actual pictures, while everything is put together the cable management is a bit of a mess. The slim noctua fan is doing a great job cooling my GPU, but the sucker can get loud.
If you look at the 1080 mini build video, Josh cracked open my 1080 mini and swapped the GPU's thermal paste with NTH1, maybe that'll help?So just did a fur mark stress test at 2560x1440, no AA, and after 10 minutes the card topped out at 86 degrees. One thing to keep in mind is that I have both ssds installed behind the GPU. I think adding a fan splitter, and placing a secondary fan behind the GPU, as well as doing a thermal pad mod for the back plate could drop temps a lot. But I'm fine with the temps.as they are, just might mod it that way in the future.
I actually did that as well, but with Arctic Silver 5. I have NT-H1 on hand now, could try that instead. I am also interested in switching over to M.2 SSDs given that I have the Asus Z270i now.If you look at the 1080 mini build video, Josh cracked open my 1080 mini and swapped the GPU's thermal paste with NTH1, maybe that'll help?
Well i don think Josh noted any changes in the video cards temps when NTH1 was added. at least in the video he didnt mention temp changes, that I remember anyway.I actually did that as well, but with Arctic Silver 5. I have NT-H1 on hand now, could try that instead. I am also interested in switching over to M.2 SSDs given that I have the Asus Z270i now.
Right now working more on the active cooling setup I have running on my HDPlex 300w ACDC. It has been performing well, but has been dropping out after 3 hours or so of Fallout 4 on max settings. Working on adding a second fan to that, to see how it's power limits increase.
I am using grizzly kryonaut which is considered the best paste, but i think it is only 1-2C better than Noctua paste. I also have two 80mm fans on mine instead of one noctua. My temps max around 74-75C under furmark. Weirdly with the new hdplex i can manage an overclock on the card. Still got more testing to do to get it just right and to make sure it can handle spikes but i never have issues. i have had 8 hour gaming sessions in: overwatch, battlegrounds, black desert online, and ghost recon wildlands.So just did a fur mark stress test at 2560x1440, no AA, and after 10 minutes the card topped out at 86 degrees. One thing to keep in mind is that I have both ssds installed behind the GPU. I think adding a fan splitter, and placing a secondary fan behind the GPU, as well as doing a thermal pad mod for the back plate could drop temps a lot. But I'm fine with the temps.as they are, just might mod it that way in the future.
Is it the Sept or an earlier batch that is currently shipping? Hoping its September, that's my order!
Mine was a September pre order that i got. I didn't have anything special extra for it that might slow it down. Just a silver switch and the flex riser cable.
Same here but black switch. But I'm not American so shipping might take a while to get here.
