Any news about the bezels? Cheers
almost done...must...finish...before sleeping...
You'll get all the sleep you'll need when you're deadalmost done...must...finish...before sleeping...
Sneak preview:
Sneak preview:
It's a clip from May 17th though![]()
Oh man... that would go beautifully with my Pok3r. Im commited to acryllic tho!
Edit: hope im not breaking any rules by posting my mech lol
That has to be one of the most idiotic things I have ever seen them do. I love it.
I'm pretty sure you'll be fine with the HDPlex 400w, people have been running a 6700Ks and gtx 1080s on the 300w version IIRC. I can't imagine you having any problems leaving it to run overnight either as long as you have sufficient cooling (which I assume you have). Hopefully someone else chimes in as well in case (no pun intended) I'm wrong but I believe you're all goodHi guys! Managed to snag a pre order for a s4 mini! First time going for a reallly super custom build! I just have a query I have been reading lots about builds regarding this case! However I am a little worried would the HD Plex 400 be fine running a i5 6500 and a GTX1070, would my systems life expectancy be lowered or effected by trying to cram all this together is it safe to leave my pc on over night? This may sound silly but I'd like to learn from the pros
Ps any video tutorials on shortening PSU [cables] and sleeving them? Or any [premade] custom packs you'd recommend for the s4 mini?
As for the custom cables; there are a number of online video tutorials about it, most notable among these are the ones by Lutro0 Customs (link to channel: https://www.youtube.com/channel/UCT7p3y4df3uwYYZI7bcdJAA) and ones by Singularity Computers (link to channel/playlist: https://www.youtube.com/playlist?list=PLWYPRHLWSBL4kY95IIpB_U_9AoFoLzJ5U)
If you're looking for ones you can buy already made for you then I'd be able to help you out if you're interested. I have my services listed in the vendor marketplace here so if that's something you'd like to do or you have more questions about it feel free to contact me here via PM or via my website/email.
Congrats on the S4 Mini order and welcome to the forum!![]()
HDPlex 400W will handle your system just fine. I think the bigger concern would be brick choice. You can likely get away with the Dell 330 W or HDPlex 300W AC-DC quite nicely. Voodoo 350W would also be a good choice if you can find one. At stock clocks you can expect the 1070 to pull about 150W with periodic spikes to 200W and the CPU to pull somewhere in the neighbourhood of 75W at peak. Given that the rest of the system won't pull more than about 25W, that should have you comfortably within budget. To give you some data to play with, I've used the 300W HDPlex AC/DC with a 7700K running Prime95 Blender and the Zotac 1080 running Furmark and it is at the upper limit of stability pulling just over 400W when peaking and right around 300W static.
Same here
I7 6700k +1070 +hdplex 300W +hp330w brick
Powerdraw at the wall ~300W
Hp brick gets only handwarm
