Leaving the Dan Case for the 3 slot card availability for the 3090.
Not sure if it's just me, but you do know that the Dan A4 doesn't fit 3 slot graphics cards?
That's why I'm leaving the Dan case for the Ncase...Not sure if it's just me, but you do know that the Dan A4 doesn't fit 3 slot graphics cards?
I also have Dan A4, backed the Mjolnir Kickstarter for what was going to be my next build, but if there no 3090 2 slot option, I might try the Sliger SM580.That's why I'm leaving the Dan case for the Ncase...
This is why I stopped paying attention to any cases that only accommodate 2-slot GPUs. It's just too restricting given the trend of the manufacturers. Had the A4, now housing my dad's PC, had a Ghost clone also but that had to go. Now happy with the T1 for its 3-slot GPU modeI also have Dan A4, backed the Mjolnir Kickstarter for what was going to be my next build, but if there no 3090 2 slot option, I might try the Sliger SM580.
For one I never have side panels on unless transporting anyways. I'm not above putting a box fan next to my computer, LM, water blocks, or listening to a jet launch off when I start a game. I like the most power possible. Also, I just sold my 2080ti and actually made money after 2 years of use, I believe the same will be true for 3090. I also like modding cases to make the impossible work. I managed 2 92mm fans, and 5 40mm in the Dan case. I travel to much and learned a hard lesson checking a desktop that it's better to be able to use a carry on, which is why I stick with itx.Why does everyone want to go with the 3090 though? Why not the potential 3080 Ti or even the 3080?... Will be a lot of heat to deal with inside such a compact space.
I don't think anyone is blaming Necere, he after all is like a founding fathers of ITX cases and a legend for adapting to products over the years. Plus he is amazing at supporting customers on forums. Also, I don't think you can blame it on power inefficiency, without an actual evolution of the technology to have more powerful CPU/GPU, will need more power. Yes, it's still rumored but most leaked cards from Nvidia with proven sources. I like to get ahead of people before products run out. If smaller cases that fit full size cards can't fit a flagship like a 3090, the ones that do will be gone for months. Yes small percentage will buy the 3090 but there is enough and SFF is more popular than ever.Pro tips: don't fabricate your builds around a rumored product. Don't buy parts of a build based around a rumored product.
Don't blame Necere for the design of the Ncase M1 that has been what it is for many years because Nvidia's new rumoured flagship GPU might not fit physically or work thermally. I would seriously reconsider if it requires a much larger heatsink and a lot more power. It's not going to be twice as fast, Nvidia has no competition at the high-end. So either the new GPUs are terribly inefficient or they are expecting AMD to be releasing a competing product.
Will the 3090 fit into the ncase?That's why I'm leaving the Dan case for the Ncase...
Beyond the likely increase in thermal output, is there any real change in this compared to traditional dual or triple fan GPUs? Sure, those have a PCB (and often a backplate) in the way and are as such not explicitly designed for rapid air movement through that area of the heatsink, but the airflow path is still similar, and as long as the case is able to exhaust the heat created by a traditional open-air GPU it should also be able to exhaust this - though the back of the PSU might get quite toasty unless some sort of insulator is added there. The only issue I see beyond the increase in heat output itself being problematic is for cases where a GPU backplate would typically rest flush against a PSU or panel, as in there would be near zero clearance for air to exit in those cases.Good article to read.
It looks like the dual fan (one in front top and one in rear bottom) design is accurate. Note the diagram for the design airflow path. So, this design is having a traditional case layout in mind. The front top fan draws air from the case's front bottom fan and then exhausts upward and hot air extracted by the case' rear top fan. Sandwich style case owners need to be ingenious to come up with a solution.
Nvidia Serves Up RTX 3090 Cooler Design Process, Explains 12-Pin Connector
Shrinking the PCB to make space for a bigger coolerwww.tomshardware.com
Not even when water cooled?
No one has any idea what size the PCB is or what the blocks will look like.Not even when water cooled?
That would work, as the PCB is like 2/3rds of the card. The 3090 specifically might still be too tall, but it might work.Not even when water cooled?
There's just some vram on the 3090 model on the back, which the backplate covers. No active cooling.There are rumors that both sides of the PCB require cooling so who know what a water cooling solution would look like.
