Wow, that is ... weird. What do they benefit from closing them off? Ease of manufacturing I guess, but ... there's no airflow there, so about 1/4 of the fin stack is entirely passive? Why?yeah there won't be airflow (or good airflow at least) from the primary fan directly above the GPU. the channels are flushed off
Also, that means the flow from the primary fan goes partly out the back (having passed over a tiny amount of fins on the way) and partly out through an extremely long, crooked and restrictive channel (some of it will do a ~135-degree turn and reverse out, losing pressure massively and creating tons of turbulence in the cooler, the rest will pass through a <1cm wide channel that's long) on the other side, with possibly even less fin area covered. This baffles me. I would be seriously interested in seeing some testing done with that fan disconnected to see how much of the cooling is done by the inner fan blowing through the stack.
