I had hoped that NVIDIA or AMD would come up with a next gen 75W GPU that could beat the performance of the GTX1650 and that we would see some new low profile and single slot cards at some point but it seems that the A2000 is as close as it gets. Unfortunately NVIDIA decided to make the A2000 a dual slot card and therefore it does not fit in many SFF workstations that are limited to single slot and low profile.
soooo I came up with an idea...
I wasn't quite sure if it would actually work to make a single slot cooler for the A2000 but as we say in Germany "probieren geht über studieren" and so I just started the project to see how it goes...
just to be safe, I went all-in with copper for this cooler and while browsing for ideas how to design the cooling fins I came across something called "copper sponge / foam"
for best heat transfer, the cold plate, heatpipes and the copper sponge are soldered together like a sandwich using a low temp solder paste at 200C for a few minutes
next up, assembling the copper backplate to the A2000
assembling the SpongeBob Copper cooler with a 5010 DELTA PWM fan
installing the shroud and hoping that it works
running some benchmarks / stress tests...
1) idle with Full Copper Low Profile Single Slot Cooler
2) Valley Bench with Full Copper Low Profile Single Slot Cooler
3) TIME SPY Benchmark with Full Copper Low Profile Single Slot Cooler
4) TIME SPY Stress Test with Full Copper Low Profile Single Slot Cooler
for reference/ comparison, results with the original dual slot A2000 cooler...
my thoughts / summery...
I was very skeptical if my cooler design (especially with the copper foam) would actually work at all but to my pleasant surprise it does quite well. The original cooler clearly performs better but to be fair it's a dual slot cooler and the turbo/blower fan certainly moves more air than the one I am using here. Anyways, I already have some ideas for improvement so stay tuned if you like this project...
