REVOCCASES submitted a new resource:
RTX A2000 - DIY Single Slot Copper Cooler Mod - RTX A2000 DIY Copper Single Slot Mod, e.g. for 1U Servers
DXF files to make your own 1-slot cooler and backplate for the A2000
how to:
- coldplate can be laser cut or CNC machined from >= 3.0 copper (3.2mm recommended), mounting holes designed for M2.5
- 1-slot bracket / backplate can be laser cut and bend from 1.0 mm copper / aluminum, mounting holes designed for M2 screws and nuts
- cut the coldplate and solder some copper fins on it using 138C solder paste
- cover the backplate with a large 1.0 ~ 1.5mm thermal pad...
